Old 06-07-2002, 02:03 AM   #1
jj93z28
Question Coil overs??
Hows it going? Well I am new to suspension mods and am looking for a little help locating a coil over kit, the LG kit is to pricey for me. A explaination as to why this is better then just regular lowering springs would be nice to. I am guessing its the adjustability.
[This message has been edited by jj93z28 (edited June 07, 2002).]
jj93z28 is offline   Reply With Quote
Old 06-07-2002, 02:57 AM   #2
Dr.Mudge
Adjustable ride height, "any" spring rate you want, corner weights, lighter than stock setup, or save your money.
__________________
98 Z28 M6 - 01 R6
An educated mind is a mind that knows that education never ends -unknown
Dr.Mudge is offline   Reply With Quote
Old 06-07-2002, 04:46 AM   #3
jj93z28
I see, so how do the other coil over kits compare to LGs one. Keep in mind I am not a serious racer so I can settle for little less than perfection.
Old 06-07-2002, 10:42 AM   #4
Lowend
checkout:
www.groundcontrol.com
www.globalwest.com
both of these companies make coilover setups for 4th gens.
I have used the Ground Control and it works very well.
The GW kit is nice in that it is tuned to work with the other GW products (torque-arm, LCA's/brakets).
The truth be told, if this is a 100% street car, a set of coilovers is probably not the best use of your $$.
Coilovers do allow adjustability, which is crittcal on a racer; but for a street car how valuable is that...
I would probably invest in a set of Lowering springs, and spend the extra $$ on a set of good weld-in SFCs.
1971 Camaro
12" brakes
16x10" wheels
VSE swaybars
350 / M21
Autocross Competitive
'83 FSP GTI (driver)
Administrator; 2nd Generaton Camaro Owners Group (2GCOG)
www.nastyz28.com/2gcog/2gcog.html
Sales / Tech
"The Speed Merchant" - San Jose, CA
http://www.speedmerchant.com/
__________________
1971 Camaro - Autocross Competitive
'95 Firebird Formula M-6
Sales / Tech "The Speed Merchant" San Jose, CA
Lowend is offline   Reply With Quote
Old 06-10-2002, 10:18 AM   #5
auto-Xer
Member
Something else about the LG setup is that its the only one that is rodended, which if your seriously roadracing, is a big plus when making your choice. For a daily driver, it means little though.
--Kevin
'96 Z-28
78k Miles
Toyo RA1 275/45Z17, SLP Coated Headers, SLP Clutch and Flywheel, G2 Coilovers (Bilstein and Eibach), LS1 Driveshaft, G2 PowerPulley, G2 CAI, B&M Ripper, G2 Pedal Covers, TB Airfoil, Borla 3" catback, G2 Panhard Rod (adj. w/ rodends), G2 Subframe Connectors, G2 Enginebay Brace (4 point), G2 Swaybars, Poly Trans Mount, Driver & Passenger Sparco Evo2 Seats, Powerslot Rotors w/ PFC Pads, Stainless Steel Brake lines, ACES SureShift2 Seq. Shift Light, Spohn Torque arm, LCA(rod/poly) and relocation bracket, McEwen White Gauge Faces.
On order: Autopower 'race' rollbar, Spacro 5 point harness, McCord Power Plate cutout, LG Spoiler and stripe, and ScanMasterLT1
Just a few parts away from my ZR-28
__________________
'96 Z-28
80k Miles
Toyo RA1 275/45Z17, Torsen T2R Diff, SLP Coated Headers, SLP Clutch and Flywheel, PCM4Less tuning (w/ LT4 KM), G2 Coilovers (Bilstein and Eibach), G2 Lower A-arm (rodended), Global West upper A-arm, LS1 Driveshaft, G2 PowerPulley, Moroso CAI, B&M Ripper, G2 Pedal Covers (Throttle only), TB Airfoil, Borla 3" catback, G2 Panhard Rod (adj. w/ rodends), G2 Subframe Connectors, G2 Enginebay Brace (4 point), G2 Swaybars, Poly Trans Mount, Autopower 'Race' rollbar, Spacro 5 point harness, Driver & Passenger Sparco Evo2 Seats, Powerslot Rotors w/ Hawk HP+ Pads, Stainless Steel Brake lines, ACES SureShift2 Seq. Shift Light, Spohn Torque arm, LCA(rod/poly) and relocation bracket, McEwen White Gauge Faces.
Waiting to install: McCord Power Plate cutout, LG Spoiler and stripe and ScanMasterLT1
auto-Xer is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
