Breaking stock swaybar mounts...replacements?
Old Jun 9, 2002 | 01:14 AM
SteveR's Avatar
Question Breaking stock swaybar mounts...replacements?
I keep breaking my stock front swaybar mounts (frame mounts). What is a good aftermarket replacement that won't break?
'94 White Z, A4 2.73s, 1/4th 13.5 @102.3, 1/8th 8.7 @81.6, 60ft 1.97sec
Mods etc. - RK Sport 1 3/4 headers, 3" cutout, Moroso CAI
E.T.F.A. Message Board * (above times are before headers)
Old Jun 9, 2002 | 07:25 AM
93zder's Avatar
Smile
I had the same problem when i went to poly bushings. I finally took a closer look at the bushings, and found the poly ones were a little longer than the stock ones. Therefore the bracket was not sitting flush with the frame and causing it to stess and break. So i thought to put a washer between the frame and bracket, and shave the bushings a little. I haven't had a problem since.
1993 red M6 Z28; custom control arms; bushings; strut bar; Eibach Pro-kit;17" rims & 275 tires; Mac exhaust; K&N cold air; airfoil; TB bypass; 3.73 gears; KVR pads & rotors; -1 camber alignment
[This message has been edited by 93zder (edited June 09, 2002).]
Old Jun 9, 2002 | 12:05 PM
SteveR's Avatar
I never thought of that...I'll look into it. Thanks!
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
