ram air vs. cold air intake
Old Jan 19, 2004 | 12:04 PM
Damen's Avatar
Ok guys, I'm kinda torn here. I've decided I want to redo the air intake on my camaro, but I cant really decide which way to go. The ram air, to my mind, just seems cooler than the cold air intake, but I can just go out any BUY a cold air intake for relatively little money and just bolt it on without any worries. The ram air setup for our cars just doesnt seem as developed. Does any one particularly out perform the other? What do you guys think?
-Damen
Old Jan 19, 2004 | 12:25 PM
kevin 2.8's Avatar
if you have the air filter setup that has the two square drop in filters, you already have cold air. drop in some k&ns
just remove the water baffles and drill some holes in the airbox under the filters and youre set
Old Jan 19, 2004 | 02:25 PM
Damen's Avatar
Ok well, is doing that any better than converting to ram air?
Old Jan 19, 2004 | 04:01 PM
kevin 2.8's Avatar
if by ram air you mean buying the ram air hood, and the ram air airbox then having the hood painted to match.. youre looking at big dollars.
or the cheap ram air is pcv piping the airfilter low enough to catch air under the car your going to get a muddy, waterlogged, dirty filter fast.
k&n drop in filters are easy and will save you $ anyway
porting your intake yourself would help even more and still cost you nothing. there are many places that show detailed instructions
Old Jan 19, 2004 | 04:10 PM
Damen's Avatar
Yea, well, lets just say that I'm not very good at building/cutting/modifying things myself.. I can design stuff, no problem, but you dont want me building anything other than a computer So I dont think porting it would be a good idea for me. Thanks for the info tho.
-Damen
Old Jan 19, 2004 | 04:34 PM
kevin 2.8's Avatar
learn
practice on a wrecker, and port the wrecker then swap them
Old Jan 19, 2004 | 09:33 PM
aklim's Avatar
I have a Cold Air package from SLP because it had a bigger inlet than the stock air box. I wouldn't go with ram air because it works great at over 100 mph. How often do you go that fast?
Old Jan 19, 2004 | 11:24 PM
doug791's Avatar
"ram air" is just a cai. You could either piece together some sheet metal to run ducting from your fog lights to the air box, or i think they sell em for like 50 bucks on e-bay i forget where ive seen them before though.
Old Jan 20, 2004 | 08:57 AM
92BLKL98's Avatar
Check out this Tech article from ThirdGen.org: http://www.thirdgen.org/techbb2/show...hlight=Ram+Air This is what I did with 1/16" plastic sheet. Some guys use .032 sheetmetal but I've had mine in the car for 8 years and it is as good as ever. Judging from the frequency at which I have to clean my
Old Jan 20, 2004 | 04:44 PM
formularpm's Avatar
Exactly, but it seems people just cant seem to grasp this concept.
Old Jan 20, 2004 | 05:00 PM
Error404's Avatar
what is cai?
Old Jan 20, 2004 | 05:03 PM
TunedPort 335's Avatar
Originally posted by Error404
what is cai?
Just an abbreviation for cold air induction.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
