07-10-2002, 05:06 PM
Need help with a clutch install
how much do these usually run (install) and anyone wanna do it on my 1996 Z? its the SLP clutch, so it should go in real nice.
thanks,
brian
__________________
2002 40th Anniversary GTP
2000 Turbo Monte Carlo SS
07-10-2002, 09:51 PM
Awww come on, I did mine. Its not so bad. I'll let cha borrow my book
__________________
RED 97 Z28 M6
Edelbrock headers, Mac cat-back, MTI intake
14.044@100.37mph 2.289 60'
lots of knock above 4k
07-11-2002, 09:08 AM
Call Ed at Gaunt Motors he only gets $45 an hour. he put in my RPS clutch and he did a great job. his number is 413 562 6969. hes located near spfld, ma. tell him dennis told you if you call him. maybe he will hook me up?
good luck dennis
9 second street legal 1989 mustang lx, special effects purple, 306 Vortech t trim 20pds of boost, momo; seats-steering wheel and shifter knob, weld drag lites, stage 2 fuel system, cervini stormin normin hood and saleen wing, tfs ported heads and edelbrock rpm intake, 8pt cage.
new project, 1994 Z28, 383 stroker, 4 bolt block with bullet main caps, cola light weight crank, H beam eagle rods, je inverted pistons 9.2 compression with heads, comp cam custom grind cam and 1.6 non self-aligning rockers, afr stage 2 heads 58cc, fully ported LT1 intake powder coated LT4 red, 3 core race intercooler, polished procharger, 3:73 gears, custom torque arm, eibach springs, custom panhard bar and control arms, kyb agx adjustable shocks, ss hood, factory ss spoiler, 58mm bbk throttlebody, B&M ripper shifter, chrome zr1 rims, autometer phantom gauges, edelbrock headers,
__________________
1995 cobra R
1996 Formula WS6 1LE
1997 Formula WS6 1LE
1998 Formula WS6
1990 black/black notch
07-11-2002, 11:59 AM
damn man, springfield is a hike, but $45 an hour is ~$20 cheaper then around here. maybe ill have to do it. thanks for the help.
brian
__________________
07-11-2002, 03:15 PM
its not too bad of a ride. from watertown/brighton it takes about an hour ten to 20 minutes to get there. he can problably do the clutch in a day. if you go saturday morning you be home by night fall. it sucks you waste a day but you'll have more dinero in the pocket. good luck dennis
__________________
1995 cobra R
1998 Formula WS6
07-11-2002, 10:47 PM
I rememebered the name of that place it is Turnpike Transmissions on Rte 18 in Bridgewater. Give em a call
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
__________________
1983 Z28: 406 + T-56 + 12-bolt = 11's
1995 Z28- Sold
1999 Z28- My new DD
04 GTO- Sold
04 Silverado 2500HD 6.0 4.10's yea its slow.....
07-12-2002, 07:31 AM
got a number for me buddy???
brian
__________________
07-22-2002, 08:52 AM
TTT, my mech has a 1 month backup and my hookup backed out, so i need a hand (will pay cash) in getting this in asap. heres what i need done:
1) install clutch assembly (pilot bearing, PP, disk)
2) replace rear main seal while we are in there (rather do it when its apart)
3) optional-install my torque arm and driveshaft loop
ill gladly help and a lift would be great. experience is a plus. drop me a message or im/email at irocz88bt@aol.com.
thanks!
brian
__________________
07-23-2002, 12:45 PM
try calling ed. he can probably do it, this weekend for you. 413 562 6969.
dennis
__________________
1995 cobra R
1998 Formula WS6
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
