Old 07-13-2002, 01:23 PM   #1
TheZ
Send a message via Yahoo to TheZ
Post rock 7/12/02
went to the rock last night7/12/02 lol it's was all imports lt1's ls1's getting smacked down by a white gsx 480-500 hp running high 11's low 12's an some purple civic running high to mid 12's lol.
cai,borla,longtube headerz,3.73,nx nos 100 in garage lol 95 lt1 a4
TheZ is offline   Reply With Quote
Old 07-13-2002, 01:47 PM   #2
94irocz
Question
So how did you run?
94z A4, white with blue pearl coat paint, !cat, 3.73's, K&N FIPK, GMMG Chambered exhaust, hooker lt's, custom y-pipe, MSD 6Al, CSI wp,!tb, cut out, 160 tstat.
Best 1/4: 13.31 @ 104 mph 1/8: 8.61 @ 82.85 mph
AIM:Gintkiller
__________________
94z stall, cam, gas
NA Best 1/4: 12.309@109.73 1.74 60'
n2o best 150shot : 11.26@121.37 1.57 60'
AIM:Gintkiller
94irocz is offline   Reply With Quote
Old 07-14-2002, 12:58 PM   #3
TheZ
well i didn't run have an some minor problems small back fire. I have a new intake elbow on the way mine all tore up, so that might be the problem also i have some tr6's that need to be put in
i saw those ls1's running high 13's lol that silver ss lt1 was sad running low 14's
Old 07-14-2002, 01:11 PM   #4
93 Indy
Quote:
<font face="Verdana, Arial" size="2">Originally posted by TheZ:
</font>
I suppose your LT1 ran 12s stock?
Chris
93 Indy Pace Car
Just like 99% of you, it ain't stock!
396ci and a TH400 by A.R.E.
If you're interested in doing business with Agostino Racing, contact me first. I'd be more than happy to share my experience.
cmcmillen@carolina.rr.com
__________________
Chris
93 Indy Pace Car
Companies I don't support
Agostino Racing or any place Nick Agostino works.
93 Indy is offline   Reply With Quote
Old 07-14-2002, 02:25 PM   #5
TheZ
12's lol naw i'm way below that 10's on a good day i'm running low 13.20@106 mph
with pep boys futura's 99.00 a pop you can't beat that but i have an nx system in the garage as we speak i just need some safely ****. looking for low 12 then i'm done
-lamont-
Old 07-14-2002, 02:27 PM   #6
TheZ
maybe next time i can meet some of cz28 finest members
btw trying to sell some-98- vette rims 275.00 a set
Old 07-14-2002, 02:31 PM   #7
rje
Send a message via ICQ to rje
Man, wish I could've been there I would've loved to play. I was there last night for the Trophy street race. We got rained out, but not before I made some good runs,(that's another post). Bob D has a new bullet in his ride and when he's done that thing will fly. Later.
Randy
__________________
94Z 383 LT1, AI 200cc Dominator LT1 heads and intake,1.75 Hooker LT's,58mm TB,Jesel shaft rockers, 42# injectors,Bullet soild roller camshaft,Powerglide/5400 TC,Moser 12bolt/spool/5.14's,tuning by Alvin@PCMforless Hoosier 30x10.5x15 radial slicks,raceweight 3300lbs.
1.32 60ft, 4.15 330ft 6.55@101 mph 1/8
rje is offline   Reply With Quote
Old 07-14-2002, 08:49 PM   #8
camaro81
camaro81's Avatar
Send a message via ICQ to camaro81
randy, whatcha gonna do if bob beats you with that new motor, get a bigger shot of nitrous? :P haha j/k
were there any rounds ran in the points race? or did it rainout before eliminations? i couldn't make it cause my car is still apart, i'm gonna try to make the next one though
__________________
Chris Rose
1995 Camaro Z28 - 383ci, custom cam, SLP CAI & Catback, 3.73's, Edge 3000 stall, CPT "Pro Race" Transmission
12.129 @ 109.93mph & 7.583 @ 90.05mph
camaro81 is offline   Reply With Quote
Old 07-14-2002, 10:58 PM   #9
rje
If need be I can always go to a 175 shot and with cool weather that's easy 10.7's.
I don't think any elimination were run except for the 10.5 cars.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
