? about T-Rex Aux FP
Old Jan 10, 2004 | 06:12 PM
Blown 96 WS-6's Avatar
Does anyone know if the T-Rex has a check valve in it too restrict fuel back flow like the in-tank pump does?
I ask because since removing my T-Rex my FP will not stay up when I turn the key to the on position. It comes all the way up and almost immediately drops all the way back to zero.
I am trying to determine if my leak down is from the Walbro. If the T-Rex does NOT have a check valve then removing it at the same time as the problem starting is coincidental. If it does have a check valve then I will assume the Walbro was bad from day one and the problem was masked by the T-Rex's check valve. That will **** me off because I'm sure I've had it too long to return
There's still a few other things I need to look at but my AFPR is also fairly new so I don't think that's it.
Old Jan 14, 2004 | 08:07 PM
lethal93ta's Avatar
the t rex dont have a check valve in it, check you regulator, I was having the same problem and just put an accel adjustable regulator on mine it fixed the problem.
Dec 17, 2014 11:00 AM
Asskikr
May 9, 2004 07:22 PM
Asskikr
Jan 30, 2004 08:00 PM
BradleyPeart
Nov 26, 2003 10:08 AM
vodoo-chile
Apr 28, 2003 12:38 PM
