Starter Kill Question
Old Jan 7, 2004 | 03:43 AM
Mr Kevlar's Avatar
I'm attempting to install my new alarm and I'm kind of stuck. I have a starter interrupt relay with 3 connections, (Normally Open, Normally Closed and To Key) Where would I hook where? Any ideas??
Old Jan 7, 2004 | 11:23 PM
Javelin3o4's Avatar
normally when you install a starter kill relay when you find the wire for your starter at the column you cut it in half and the "key" wire will go on the half of wire that is going into the steering column, and the other half will go to the starter side. what kind of alarm is it?
Old Jan 8, 2004 | 04:15 AM
Mr Kevlar's Avatar
It's an Alpine SEC-100S, The wire im talking about are coming from a relay. Do you know by any chance what color the wires im looking for are?
Old Jan 9, 2004 | 01:07 AM
Javelin3o4's Avatar
the starter wire is yellow, bundled in the ignition harness at the bottom of the steering column, you can test the wire with a multimeter, it should show 12v when cranking the engine. when you think you found it. cut it in half and try to start the car obviously if it doesnt crank you got the right wire, then just wire up the relay.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
warmeck
Feb 5, 2015 11:04 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
Brent94Z
Mar 21, 2002 04:44 PM
