eibach prokit
Old Dec 10, 2003 | 12:41 PM
faSSt97's Avatar
eibach prokit
Will the 93-97 Eibach prokit fit onto a 98 or up camaro? Thanks
Old Dec 10, 2003 | 02:02 PM
19ss99's Avatar
yes they should fit. But you might have to make height adjustments to them. Could be wrong but lt1's (engine) weighs more so theres a chance the ls1 might now sit as low. but yes they will fit
Old Dec 10, 2003 | 02:28 PM
Steve0's Avatar
I believe teh LT1 eibach springs are progressive rate, while the LS1 springs are not.
Old Dec 10, 2003 | 06:20 PM
chuck's Avatar
Yes they will fit, but as stated, the LT1 springs are progressive all around, the LS1 springs are linear up front. Both use the same progressive rear springs. I prefer the LS1 springs, but the ride height is about the same.
Old Dec 10, 2003 | 11:33 PM
WipeOutXXL's Avatar
BMR
Dude, if you plan on putting headers on your car, DO NOT GET EIBACH'S, that's what I had but headers stick low and the Eibach kits lower the Camaro to much. Go look into BMR springs. They will not lower the car as much. With Eibach's you will shave your headers right off of you live in bumby neighborhoods.
KYWes
Aug 10, 2015 07:03 PM
Dark Angel
Aug 16, 2002 04:58 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
DarCwuN
Jul 31, 2002 02:01 PM
DarCwuN
Jul 11, 2002 05:34 PM
