What do you think of this Engine Combo?
Old Dec 2, 2003 | 08:03 PM
KC-71's Avatar
I decided not to go with supercharging a crate on my 71 Camaro because with higher compression and low boost it won't put out the numbers I want. So instead, I am going to build my own engine from top to bottom.
*I want to bring my car to the track somewhat often as well as it being a weekend cruiser so reliability isn't at the top of my list*
Okay here's the main parts I'm thinking of for the 350:
Block: Dart Iron Eagle (9.025 in deck, 4.125 in bore)
Pistons: Speed Pro (Forged) Flat Top
Connecting Rods: Manley (Steel) 5.7''
Heads: Edelbrock Victor Jr. 23* (70cc)
Cams: Comp Cams Magnum Hydraulic (286/286, maybe 292H)
Intake: Either Edelbrock Victor Jr. or Edelbrock Air Gap RPM
Carb: Demon 800
*I already have an entire MSD ignition system (distributor, wires, coil, and box)
Lastly, I have a TH-350 and will put in a 3000 stall. Thanks for the help.
Old Dec 2, 2003 | 08:16 PM
DarthIROC's Avatar
what ci are you wanting to run? If your gonna shell out the cash for the Iron Eagle block you should pull a 434 or something. Otherwise the block is a waste of money.
Since your gonna be spending alotta money on the block, might as well take a step up and buy weisco or ross pistons. They are better than the speed pros
Old Dec 2, 2003 | 08:51 PM
FiefSS's Avatar
yeah, try to get largest amount of cubes out if, going for more $$$ block get the most out of it possible
Old Dec 3, 2003 | 08:59 AM
69camaro383's Avatar
Thats pretty cool. You should be fast. Good luck.
Old Dec 3, 2003 | 09:21 AM
81Z28355's Avatar
Max cubes, Super victor Jr. AFR 210 heads, JE or weisco or ross pistons, a good forged crank and rods Holley HP or Demon carb and a huge solid roller cam. If you plan on spraying it in the future keep that in mind for the cam and pistons. If you spray it go for alot of comp. and just run 110 octain all the time. I have a buddy in the low 9s with a similar combination with a 300 shot of gas.
Old Dec 4, 2003 | 04:06 PM
Quick69's Avatar
everything look great but why not go with a solid roller cam instead, I've got one in the 406 and love it
Old Dec 4, 2003 | 06:34 PM
oldschoolfella's Avatar
engine combo
i would go with the air-gap dual plane! all else sounds killer!
Old Jan 4, 2004 | 02:18 AM
LameRandomName's Avatar
If you're using that block you can go 4.185 x 4.125 and get a 454 small block.
And if you aren't using a power adder, then go for 6" rods.
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
92ragtop
Dec 27, 2014 01:56 PM
Nostang 96z
Sep 15, 2002 10:15 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
