Old 06-07-2002, 01:43 PM   #1
95BlackZWannabe
Send a message via ICQ to 95BlackZWannabe Send a message via AIM to 95BlackZWannabe
Post WTB: A/C Condensor for my 94 Formula ASAP
Please email me asap if you have one. thefrappin@att.net with price!
95BlackZWannabe is offline   Reply With Quote
Old 06-13-2002, 01:32 PM   #2
mr diabolical
Member
hey you got a new car?
__________________
1989 350/N20 IROC-Z M6 (Current)
The IROC after I let my brother drive it in '00
Interior from 95Z in my IROC
New Motor!
350:
Bored .030, JE Ultralight Forged Pistons, Manley Forged Aluminum LightWieght Rods, Scat 4340 Forged Superlight Crankshaft, ARP 2 to 4 Bolt Splayed Caps, GM 847 Cam 234/242 .575/.595 w1.6RR 112LSA, Comp "R" Series Lifters, Comp Hardened Pushrods, Pro Action Lightning Aluminum 58cc 200cc Ported and Polished by me, Comp ProMagnum Chromemoly Full Roller 1.6 Rockers, Manley RaceFlo Stainless Valves 2.05 & 1.6, K-Motion 1.625 Valve Springs .750 Max Lift, K-Motion 10 Degree Locks, Composite LT4 Valve Covers, Polished Stealth Ram Intake, Heddman Coated Longtubes, 3 Inch Custom Exaust w/ Flowmaster Single Chamber 3 Inch Out, 95 T56 Rebuilt, SPEC Aluminumn Flywheel, SPEC Stage 3 Six Puck Carbon Clutch, SLP Modified LT4 Pressure Plate, Balanced Steel DriveShaft, 4th Gen Rear Axle with Eaton Posi, 3.42 Gears, 17 Inch WS6 5 Star Wheels, Spohn LCA Relocation Brackets, Spohn Adjustable Torque Arm that bolts to Spohn Crossmember (no more broken tranny mounts), Spohn Adjustable PHR, Spohn Adjustable LCA, Spohn LCA Relocation Brackets, Spohn Tubular SFC, Poly Bushings from Front to Back.
mr diabolical is offline   Reply With Quote
Old 06-15-2002, 02:54 PM   #3
95BlackZWannabe
Yup. White '94 Formula Had the tranny rebuilt race ready(A4), Nitto 555's, cut out(soon to be true dual w/Hooker LT's, Dr.gas X-pipe and 2 bullets ), G2 CAI, 58mm TB, and a few other things Im forgetting. A friend of mine is selling his LS1 motor in a year or so...Im thinking of taking it off his hands...having a freak early Formula
Hows your car doing?
[This message has been edited by 95BlackZWannabe (edited June 15, 2002).]
Old 06-15-2002, 10:16 PM   #4
mr diabolical
Member
its running good, except for the clutch and a header gasket. im in the process of buying a street twin clutch from taner so that area is going to be taken care of soon. on the headers, im just going to rip out the shorties and put in some long tubes with a 3.5 inch mufflex system. so how do you like your new found power?
-T56
-3.42
-Chip
-150 Wet Shot
(273RWHP 361RWTQ)
(314FWHP 415FWTQ) (15% factor)
__________________
New Motor!
350:
Old 06-16-2002, 01:39 AM   #5
95BlackZWannabe
New power is great Im running 8.9's! Not too bad for my baby...although shes about to get ALOT better
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
