Time for 12 bolt
Old Nov 23, 2003 | 10:28 AM
TEXASZ's Avatar
Time for 12 bolt
After more than ten 10 second passes, the 10 bolt finally gave up. Not bad for running 4.10's in a stock rear. We are going to a Strange 12 bolt with 4.10's and a full spool. Anyone have an idea how much the extra weight will slow us down? Hopefully not several tenths. Ha Ha.
Old Nov 23, 2003 | 10:45 AM
Stephen 87 IROC's Avatar
http://www.chevyhiperformance.com/te...les/0304_nine/
Old Nov 23, 2003 | 10:08 PM
96z's Avatar
96z
I cant believe it lasted that long!
Old Nov 25, 2003 | 10:57 AM
Camaro_Guru16NY's Avatar
He He 10 bolt goes BOOM funny. Sorry about your luck man i dont think a 12 bolt takes off that much time but probably some if you dont have the HP and TQ to make up for it...
Later,
-John
Old Nov 25, 2003 | 11:57 AM
JWINN's Avatar
Hey John,
You have a car that is running as fast as yours is why not go with a Mark Williams Ford 9"? These rear ends are much lighter then the 12 bolt and IMO stronger. You can actually have a chromoly 9" housing made for super weight savings.
I run a custome chromoloy 9" housing with Stranging Engineering Ultra case senter section with a titanium spool and pinion yoke with the big 9.5 ring and pinion. This will never break and is way lighter than the 12 bolt.
Old Nov 30, 2003 | 09:25 PM
"White Knight"'s Avatar
No Ford for me
Just ain't right....IMO
Old Dec 1, 2003 | 01:47 AM
scott9050's Avatar
Since the 12 bolt is similar in strength to a Ford 8.8, yeah, the 9 inch Ford is stronger.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 18, 2014 12:57 PM
