Middle Atlantic New Jersey, New York, and Pennsylvania
NE Ohio guys, next year plans?
Old Nov 18, 2003 | 01:51 PM
CANTONRACER's Avatar
Anything on the cooker? New combo's?
Old Nov 18, 2003 | 10:42 PM
99snkklr's Avatar
Been a while since I posted here...but I will have some plans for next season. I plan on a 12 bolt/h-c for00 WS6 and maybe a juice kit for my SS.
Old Nov 19, 2003 | 01:11 PM
supersp0rt's Avatar
LS6 intake, 8psi, retune, cage...run 10's.
Old Nov 19, 2003 | 01:17 PM
Can't go wrong with turbo's...costly...but strong.
I am going with AFR LT4 220 heads, big solid roller, more compression, more stall, less weight....should run mid 10's if all works out on mota.
Then I spray a 150 shot.
I wonder if Dragway 42 will look at my car and tech it?
Old Nov 19, 2003 | 07:03 PM
Gary 95 Z28 M6's Avatar
I can't decide between a new cam and maybe heads or nitrous........and eventually a 12 bolt But my main goal is to get my damn knee back to normal!!!!!!!!
Old Nov 20, 2003 | 11:16 AM
Grease's Avatar
I'm not going to do very much this winter. The most expensive thing might be 15x4 and 15x10 centerline Telstars and BGF drag radials. And drag shocks for the rear.
There are 3 things i need to fix with my car though
1 - change my valve springs from CC987s to CC985
2 - Get a new y-pipe, the one on it now is only 1.75" at its narrowest point.
3 - Port my intake for the 58mm TB and the larger intake runners in my heads.
With the horrible restrictions gone in my exhaust and intake, the right valve springs and my PCM retuned, I hope to break into the 11s even with a 1.9x 60ft. I'm guessing I'll need about 420rwhp.
Old Nov 20, 2003 | 12:35 PM
supersp0rt's Avatar
with as big of a cam as you have in there, exhaust flow is critical. open that up and youre golden.
canton, i dont think 10's should be a problem at all with that combo, that sounds pretty badass, esp. spraying it.
with the way NHRA just raised the bar for t-top equipped cars, i wonder if IHRA certified tracks (like 42) will look to do the same. i know its all part of playing, but im not ready to hack up my interior and put in a 10-point. as im sure many other mainly street driven cars are not as well, just seems a hair excessive to me.
Old Nov 20, 2003 | 12:55 PM
I am sure they start looking at MPH also.
Old Nov 21, 2003 | 07:09 AM
Grease's Avatar
Originally posted by supersp0rt
1999 Camaro SS A4
QMP Single Turbo @ 6psi
11.73 @ 123.08 (1.99)
I just noticed you finally hit 11s, big time Congratulations!
Was it the VHT traction compound or were just lucky enough to get it to hook up on its own?
With the mph you're running, you'll need a parachute by the time you get into the low 11s
Old Nov 21, 2003 | 07:18 AM
95_RipperZ's Avatar
New tranny. Looking at a Combination Motorsports Level 3 tranny since mine busted, 3500 stall, and 3.73 gears. Then maybe a 58mm TB and some 30# injectors. I would like to get it dyno tuned too but I'll wait til BigShot gets their equipment.
NEO should have some pretty fast F-bodies next year. I hope to touch into the 11s with mine. It should be at least good for low 12s considering all my times thus far were on a slipping tranny and street tires.
Old Nov 21, 2003 | 06:59 PM
DarkHorse's Avatar
Well, my plans include your old heads, cam, and the rest of the stuff i'm getting from ya. But, you already knew that
Hehehehe, that was a funny picture that you sent me today too. Didn't get a chance to email ya back, I'll call you tomorrow. Got my Win2k test rescheduled for Monday.
Old Nov 22, 2003 | 11:46 AM
supersp0rt's Avatar
thanks grease!
it was my last run the last time we were there...you had just left and i made one last pass. im sure the vht helped, but i did a pro-stock like burnout as well i knew it was a good run because the car finally stayed straight off of the line.
Old Nov 23, 2003 | 07:21 PM
DarkHorse's Avatar
Lol, I remember that night. Isn't that the night that you had VHT all over your hands? hehehehehe
Old Nov 23, 2003 | 07:33 PM
supersp0rt's Avatar
ya thats it alright...royal pain in my *** to get off...hands smelled like that **** for another day too
is bigshot getting LT1 and LS1 edit??
Old Nov 24, 2003 | 10:13 AM
Grease's Avatar
It will be a loooong time before bigshot gets LT1 and LS1 edit. especially LS1 edit becasue they need to have a different version for each year of LS1s. The only thing they have now is Ford, and it takes a while to figure out the software and the car.
If you are really interested in dyno tuning, I've been corresponding with Kennedy's Dyno Tune in Newyork. They have it all for LT1s, LS1s and even Accel DFIs and FAST pcms. I'll be making a road trip out there next spring.
