Help me choose the right carb size!!
Old Nov 15, 2003 | 10:32 PM
CamSS's Avatar
This is my setup:
80 Camaro
350 .040 over
10:1 compr.
Ported Vortec heads w/ 1.6 rollers
Comp XE268H cam
RPM Air Gap
2400 Holeshot conver.
TH350 w/ shift kit
3.73 gears
I'm going with a Holley Avenger... just trying to decide between a 670 or 770 cfm.
This will be a street car, but not a daily driver. It will be spun to about 6500 rpm's. Thanks
Old Nov 15, 2003 | 11:22 PM
DarthIROC's Avatar
Honestly I dont think you could go wrong with either of thsoe cfm's. If you arent gonna drive it everyday, I would go with the bigger one.
Old Nov 16, 2003 | 03:13 AM
Dirt Reynolds's Avatar
I'd suggest you go for the 770. That combo is going to be making some power, and I'd say the 670 will be a bit small for this application.
BTW - your gonna love those Vortec heads.
Old Nov 16, 2003 | 07:45 PM
Chads71camaro's Avatar
Re: Help me choose the right carb size!!
Originally posted by CamSS
This is my setup:
80 Camaro
350 .040 over
10:1 compr.
Comp XE268H cam
RPM Air Gap
TH350 w/ shift kit
3.73 gears
I would go with the 770 with that combination but for the money you will spend on the Avenger I would go with a Speed Demon. They are not much more then the Avenger.
brothaslide
Jan 9, 2016 12:11 PM
RX Speed Works
Aug 20, 2015 03:40 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
john henry
Aug 14, 2015 08:33 AM
colts0455
13
Aug 7, 2015 09:15 PM
