how much n2o on stock lt1
Old Nov 3, 2003 | 03:00 PM
1995greenTA's Avatar
hey guys there is this kid with a ls1 camaro with a few things done to it, in town that says he has the second fastest car around(right under my buddies 69 supercharged camaro...well hes not even close but i want to just blow him away so how much could i spray on a stock lt1 and be safe? or should i just wait until i have the normal bolt ons before i do this?
Old Nov 3, 2003 | 08:05 PM
RacinLT1's Avatar
with stock fuel and ignition system i wouldnt go over 100,and make sure to get rid of the platinum plugs.b
Old Nov 3, 2003 | 08:26 PM
Z28ROC's Avatar
I totally agree.
Old Nov 3, 2003 | 11:13 PM
lt1camaroman93's Avatar
i spray 150 on stock timming and stock fuel system with 100octane with a ngk tr6 plug.. some may not call it safe but it didn't fail me.. now i got smart and put a msd digital 6 plus in to pull timming only when the nitrous solenoid is open. definatly ditch the stock plugs and go with something a little colder.
Old Nov 5, 2003 | 03:48 AM
a walker's Avatar
I have run a 175 wet shot for almost 4 years now with just the mods in my sig. Call it lucky...I call it fun I have since upgraded my fuel pump to the Walbro 255 lph unit though.
Old Nov 6, 2003 | 03:17 AM
soontobeGN's Avatar
awalker, what kind of times are you seeing with your set-up, just curious.
Thanks
Paul
Old Nov 6, 2003 | 08:14 AM
ollie-99's Avatar
yeah me too
Old Nov 6, 2003 | 12:44 PM
a walker's Avatar
My best run to date was is 11.63@118. That was with 4.10 gears and ET Streets, and spraying off the line. I knew it was going to break the rear, but I wanted to run a fast time. Rear didn't break, so I tried to back that time up with a repeat, and broke the rear
Old Nov 7, 2003 | 11:36 AM
hot_red_z28's Avatar
On your stock LT1, you could run up to a 150hp wet kit without any problems. If it's installed correctly that is...
Old Nov 9, 2003 | 10:01 PM
Pandamonkey's Avatar
Is a 50 shot enough to get a seat of the pants feel?
How much will this affect the times of a stock LT1?
Or will it turn into a "Gotta have more" thing........
Old Nov 13, 2003 | 01:47 AM
CamZ2811's Avatar
I can hardly feel my 100shot...
but my homeboy has 150shot on his 97ss feels great!!!
50 WILL NOT CUT IT!!
Old Nov 13, 2003 | 06:16 AM
the lowest i went was a 75. i couldn't feel it.. but my 150 is definatly noticable.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jlo
Feb 3, 2015 09:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
