Freescan help!
Old Oct 23, 2003 | 05:08 PM
johnny o's Avatar
Unhappy Freescan help!
I hooked the cable up to my laptop and started Freescan 2.10 but I am not getting any readings. I have it on COM1 with a 100ms delay but nothing seems to be showing on the daskboard or status page. Any ideas?
Old Oct 24, 2003 | 01:06 AM
Vomit God's Avatar
I made my own cable and it works great..
Does your cable have the ALDL connector and everything?
The only issue I've ever had was when using serial extension cables.. If the extension is cross wired (not a true extension), it wont give you anything..
The only other thing would be to ask you if the com port is enabled and properly functioning... You can plug a serial mouse into it and check that way..
Old Oct 24, 2003 | 06:30 AM
DOOM Master's Avatar
Do you have it set to interact? If you don't, it's not going to get any information. Get it to interact before you hit the start button.
Old Oct 24, 2003 | 11:05 PM
johnny o's Avatar
I set it to interact and everything works good now thnx
timmy39120
May 2, 2015 05:12 PM
DarkHorse
Apr 8, 2003 05:47 PM
Blk94Z28LT1
Mar 15, 2003 11:02 PM
JeffK95Z
Nov 13, 2002 12:50 AM
Dave 96TA
Sep 24, 2002 04:10 PM
