Hello everyone.
Firstly I would like to say nice site. My name is Gene Angelino, owner/operator Lincolnmotorsport East Coast Operations.
I found this thread while reading another related thread on our Lincoln Club Message board and felt I should chime in and let you Guy's know a little about the Lincoln Mark VIII.
The bone stock 1993-1995 Mark VIII's run a consistent 14.60 @97 mph all day long.
Thats weighing in at 4100 lbs with driver and an open end 3.07 gearing too.
The 96-98's run a little slower usually in the 15.00/15.10 range at 95-96 mph. This is due to a softer more Luxurious transmission programming and terrible timing programming on the engine tuning side.
This is corrected with the proper chip so the 96-98's can also be made to run nearly as well as the 93-95's.
They respond unbelieveably well to minor bolt-on's.
I run 13.40's @102 and change, with basically our chip, mass air kit, fuel pump, fuel pressure regulator, QuadX exhaust system, MSD 12.5mm Experimental wires, Metal Matrix Carbon Composite driveshaft, PI 3500 stall 9.5 inch lock-up converter, poly urethane IRS carrier bushings, 4.10 gears with an Auburn posi unit and a few other mod's.
Click this link for more on "King Mark The VIIIth"
http://www.lincolnmotorsport.com/press/#
Then click the November 2000 Issue.
This is good for those times all while getting 29/30 mpg on the highway.
Don't think for a second a Mark VIII cannot put some Camaro's to shame.
Here's our Baddest Mark yet. This is Chris Kaiser's of Lincolnmotorsport West our Vegas Location. This car is over 600 hp.
This is my car, The TerminVIIIor" formerly "King Mark The VIIIth"
The Mark VIII engine differs from the Cobra only in the crank, exhaust cams, oil pan, oil filter adapter, windage tray and intake manifold.
Heres a few other Misc pictures.
If you really want to be freaked out by our SuperMark, which has 3 EEC's, 16 (Sixteen) 24lb injectors and two 80mm mass air meters feeding an Eaton with an aftercooler at 12 lbs of boost then click here:
http://www.lincolnsclub.org/cgi-bin/...um=DCForumID12
Check this out too.
Well I hope this sheds some light on what probobly is the most "Misunderstood Muscle car" ever made.
Most of all just make sure you think twice before you line up with a Mark VIII, especially if it has a Lincolnmotorsport decal on the 1/4 window.
Enjoy.
