Vibration at 3500 rpm
Old Oct 1, 2003 | 02:11 PM
USA1's Avatar
Question Vibration at 3500 rpm
91 Z-28 5.7 .....vibration at 3500 in my driveway in park. Checked the balancer appears to be ok...any ideals ? Can the torque convertor cause this ? Also vibration comes in @ about eighty miles per hour on the highway at about 2700 rpms..driveshaft ahs been balanced as has the wheels..Still searching ?
Old Oct 1, 2003 | 03:49 PM
teke184's Avatar
bad motor mounts and that is just the engine speed that creates the right frequency to make it noticable?
since it's in park it can't be anything behind the tranny right.
flex plate broken?
Old Oct 1, 2003 | 05:16 PM
USA1's Avatar
Can a flex plate cause that ?
Old Oct 1, 2003 | 09:29 PM
aklim's Avatar
This is simple to check. I would raise the car, remove the flexplate shield and shine a flashlight. Rotate the engine and you can see the entire flexplate. Turn it via the crankshaft bolt. If that is fine, have you checked the harmonic balancer? You would need to set it to TDC for #1 and see if it is at 0. Your balancer could have come off the rubber and rotated out of place.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
