09-30-2003, 05:21 PM
3rd Gen Tech Moderator
Airbag removal...
I want to remove my passenger airbag.
1. Is there any way, through program to eliminate the airbag code that will go off?
2. Will it disable the entire system?
3. Do I risk accidentally setting them off?
09-30-2003, 05:28 PM
you can just put a resistor in the plug for the airbag, I'll try to get the resistance tommorow, the airbag controller will think there is still a bag in the circuit
__________________
ASE Certified Master Technician
2004 Blazer Xtreme, Indigo Blue
1990 K5 Blazer LT1/700R4/NP241
1989 Camaro IROC-Z **SOLD**
MichiganSpeed
09-30-2003, 06:29 PM
Get outta here! That'd be sweet.
You don't think anything will deploy, do you?
Steve
09-30-2003, 06:34 PM
You can put the resistor on the brown wire or just cut it and tape off the ends with electrical tape.(that's how I got mine to go off)
__________________
LALO aka ZipTie
95 Z28 A4 Daily Driver
95 TA M6 Rarely Driven
06 CBR 1000RR
09-30-2003, 06:35 PM
you should have no increased risk of airbag deployment with a resistor in the pass airbag plug, the controller doesnt know the difference
make sure you disconnect the batt about 10 min before disconecting any airbag connectors though
I should be able to get the resistance value tomorrow, I have a friend that works at a pontiac dealer
__________________
MichiganSpeed
10-02-2003, 09:50 PM
Any luck, bud?
10-02-2003, 10:28 PM
whats the weight on the passenger airbag?
10-02-2003, 10:58 PM
Hate to sound like Mr. Obvious, but why not just go ahead and pull the thing, test across the leads with an Ohm meter, and make a trip to Radio Shack?
__________________
"The cosmos is all there is, or ever was, or ever will be." Carl Sagan
10-03-2003, 07:08 AM
Quote:
I personally do not want to test across the leads of the detonator circuit of a live explosive charge
Quote:
Originally posted by steve10358
Any luck, bud?
not yet, I havent been able to ge ahold of him
__________________
MichiganSpeed
10-03-2003, 07:12 AM
Even better yet, why not just BYPASS the entire thing all together
Do what I did, take all of them out, remove the airbag light outa the dash, sell the airbag's and buy go fast stuff
10-03-2003, 08:44 AM
Thats my plan. How much did you get for your airbags? Is there a writeup on how to take them out? I have no idea where to start besides taking the dash off.
__________________
Ryan
1999 Trans Am WS6 (new toy)
Sold and missed 1995 Z28
13.143 @ 109.63 w/2.17 60'
10-03-2003, 11:13 AM
Quote:
I got like $300 for both of mine.
No write up that I know of. Pretty much just pull the dash and rip them out  Like I said, I just disconnected all the lil Air Bag computers and sold those too  There's one in the passenger side behind the glove box, it's a square metal box. Then there's another one in the center console like right below the cup holder in the center console. Pretty much everything that had yellow connector's was all air bag crap. Then I just removed my air bag light so I didn't have to look at it being on.
Good to go from there
BTW that passenger side one was pretty heavy
11-15-2003, 11:58 AM
When you pull the airbag put you need 1.6ohm of resistance to fool the computer into thinking the airbag is still there. I used two 3.3ohm resistors in parallel on my 2002.
__________________
2001 Camaro SS, red, SLP lid.
2002 Z28 M6 Stripped, Dark blue, Hurst, Magnaflow, K&N FIPK, JetHot Hooker headers, Carsound Hi-flow cats, Mufflex 3" Y with Racemaster collector, !CAGS, 17" TT2's - SOLD
07-14-2007, 03:42 AM
When I traded this Z28 in they called me the next day asking for the airbag. Apparently they could only sell it wholesale without one and dealer cost was over $1000.
__________________
02-05-2008, 12:03 AM
Been searching and can't find it.
How can I remove the passenger side airbag? I'm puttin 97+ dash in and I have the dash sitting right here and don't see how to remove it. I hear its like 8 bolts but  or will the 97+ Bag work in my 95? Same Plug?
__________________
95 Z28 97+ Interior swap, Silverstar Sealed Beam Conversion
3000 Fuddle Racing Stall Converter and Performance Built Transmission
Quote:
Originally Posted by Mighty
See, that's where it gets confusing. It was so good that it felt like our balls were touching.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
