1996 SS=13.6 stock
1996 SS=13.6 stock
Is this a little better than normal for a 96 stock SS, slp options include exhaust, differential, upgraded torsion, and hurst shifter?
It was about 65-70 degrees outside
R/T = .517
60' = 2.092
330= 5.788
1/8 = 8.845 @ 81.52 mph
1000 = 11.459
1/4 = 13.666 @ 102.4 mph
doing all of this on a set of almost worn out BFG comp t/a's
how much better have you guys seen a stock LT1 run, because I've not seen anything better than a 13.8 at Beech Bend.
R/T = .517
60' = 2.092
330= 5.788
1000 = 11.459
**I'm not calling anyone a liar**, but I find it hard to believe that STOCK LT1's are capable of mid 13's when most stock LS1's are usually only good for mid-low 13's
. When you guys are saying "stock", do you mean straight from the dealership to the track? or is that "stock", but with a set of E/T Streets and maybe some weight reduction or something?
I find it hard to believe that a stock LT1 ran 13.3, yet my LS1 only ran 14.1 on its first night at the track?
(granted, it was extremely hot and HUMID).
BTW: My buddy just took his 1998 Z28 and the best he could get from it was a 14.2XX at 99.XX. It's an A4 so I'm guessing that makes some difference and he has brand new toyo's of some sort on there.. maybe not the best tire for dragging, but it could have been a drivers race (not being one to brag on myself, thats just how it seems to me)
OK, I guess it's possible then with the upgrades, good gearing (3.23's or 6-speed) and likely good tires
. It's probably a combination of bad gearing (2.73's) and/or bad tires on an LS1 that hurt their performance. I suppose with better gearing/tires, most stock LS1's would be good for low 13's or high 12's?
From: I reached back like a pimp and smacked that LS1....
A friend of mine bought a beat to hell 95 Z28, 6-speed. I mean, this thing was a real POS. Bald stock tires, dented to hell, even the stock air filter. I watched him roll a 13.7 @102 the first time ever at the track. I wouldn't have believed it if I hadn't seen it with my own eyes.
There are some anomolies out there, and I don't mean just the car. It takes the right car, driver, conditions, luck.
