can stock crank/rods with forged pistons and 12:1 compression take a 150 shot?
Old Aug 8, 2002 | 05:16 PM
blksgZ28's Avatar
Post can stock crank/rods with forged pistons and 12:1 compression take a 150 shot?
I'll be doing a rebuild on the motor soon, I'll be getting the stock rods shot peened and I'll be using the stock crank shaft. I'll be using ported heads/intake and I plan on using the LT4 hotcam as well. Will my rotating assembly handle a 150 shot of nitrous?
Old Aug 8, 2002 | 05:55 PM
Kain's Avatar
If I had that combo, I'd run 110+ octane gas when I sprayed. I wouldn't do it on 93.
Old Aug 8, 2002 | 06:01 PM
blksgZ28's Avatar
why?
Old Aug 9, 2002 | 11:28 AM
drop top steve's Avatar
Detonation! That's a lot of comp for 93 octane fuel. You could use a seperate fuel supply for spraying. Crankshaft parts exiting thru the oilpan is not a pertty sight, plus it makes a mess.
Old Aug 9, 2002 | 12:49 PM
George Debski's Avatar
Hey blksgZ28,
I've been running for 2 1/2 years on my bone stock cast bottom end LT1 on 93 octane and NO knock sensor with a 2 stage 200 shot.
The car is just getting stronger
I run 33 deg timing on the juice and have a killer fuel system. My 4400lb 4 door grampa car has run a best mph of 117.9 and a best ET of 11.79 on the stock bottom.
My set-up in an F-Body would run 10.9s/11.0s and 124/125 or so.
SSMOKEM
1995 Impala SS "Cherry Bomb"
Best ETs: faster than my '65 pickup
Mods: 93% stock
My Super Impala SS Website
LeftoverChinese
Jan 14, 2024 03:03 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Queens94z28
Nov 20, 2014 06:03 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
