confusion about timing on bottle?????
Old Aug 1, 2002 | 12:17 PM
NJ SPEEDER's Avatar
Question confusion about timing on bottle?????
hey gang,
i keep hearing conflicting things about how much timing to leave in or pull with different power level shots. the motor i am plannign is a 10:1, iron headed, 406 inch motor, that will be shifted around 6500.
how much timing should i pull with a 150shot? a 200shot? a 250shot? a 300shot?
should i pull timing from base or total? i am runnign dfi, should the timing pulled be progrsseive or a set amount?
thanks guys,
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Aug 1, 2002 | 12:31 PM
KTamez's Avatar
1 degree for each "25hp" added is a fair BASE to start with. You'll want FULL advance that you can use, then retard from there. I think you're over complicating it. You want to pull the timing only once the system is engaged. At that point you need to pull x* out, via an ignition box, or an add on to it....
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Aug 1, 2002 | 01:31 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
DFI can pull timing on the bottle only, thats what he is talking about doing.
run as much timing as you can get away with..
2deg per 50hp is safe.
-94 Black T-Topped Z28 M6, 10s, and daily driven!
-96 CBR F3, modded of course
-92 Talon Tsi AWD, also too many mods..
-99 Tony Kart
http://www.fastblackcar.com
calaban
May 18, 2020 06:43 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
squirrels
Jul 13, 2002 01:58 AM
