Old 06-22-2002, 02:25 AM   #1
LT1S10
Question Nitrous is Pulsing from 2nd gear on. What are some causes?
I'm running a custom dual fogger nozzle NOS kit with Cheater solenoids. 40N and 30F ran great and is around a 100 shot on my car. I stepped up to 46N and 40F and it started surging on me. I am running a FPSS and a Walbro 255lph pump. The FPSS is set a 32 PSI, so I really dont think the FP is dropping that far, I could be wrong but what else could be causing it. I'm also running TR6 Plugs gapped at .035 and did pull 2 degrees of timing on the 150 shot. Full bottle at start of night and this pass was number 4 so the tank should have been plenty full as well.
Thanks guys for your help!
Mike
1994 Z/28 M6, Green/Gray Metallic, Custom NOS System,JHC Hooker LT’s, 3.5 inch S&S Racing Y-Pipe, 3.5 inch S&S Racing Exhaust, Pro 5.0 Shifter, Accel 300+, LT4 KM, MSD 8.5 Wires, K&N FIPK, TB Airfoil, 160 Stat, ASP Underdrive Pulleys, Star Stage III Clutch, Weld Draglites w/BFG Drag Radials.
__________________
1994 Z/28 M6, Green/Gray Metallic, Custom NOS System, 306 Cam, Stock heads, Hooker LT’s, Mufflex y-pipe, 4" Bullet, Accel 300+, K&N FIPK, Star Stage II Clutch, Moser 12 Bolt, Weld Draglites w/28X12.50 ET Streets.
LT1S10 is offline   Reply With Quote
Old 06-22-2002, 01:32 PM   #2
Z28ROC
Z28ROC's Avatar
Sounds like bottle pressure. Do you have a bottle heater? if so what was your pressure? And also what size bottle are you using? I've heard complaints about 15lb bottles causing surging.
Mario,
White 94 Z28
Yeah I got a few mods
Video
__________________
Mario,White 94 Z28
Video
Black 87 IROC-Z
04 KFX 400
Z28ROC is offline   Reply With Quote
Old 06-23-2002, 09:57 AM   #3
LT1S10
I do have a bottle warmer and my pressure was over 900. Any other suggestions.....
Thanks!
__________________
Old 06-24-2002, 06:58 PM   #4
MorePower4me
I had a similar problem, The cause of mine was the N20 Line routing. I had a couple of sharp bends using AN fittings, and that caused it to surge. It could be that, or perhaps you are not running big enough Lines???
1994 Z/28, M6,T-Tops
TNT F1 Wet Kit, Centerforce clutch,
17" SS wheels, 275 Goodyear F1's, K&N CAI, HPP 3, 160 Thermostat, 3" custom Cat-Back exhaust with glasspack, Ported MAF, Hurst Billet plus shifter,Cold-air scoop, and an additonal mod or 2 for extra fun.
__________________
2001 ZO6
-Stock
See it here...
Corvette ZO6
MorePower4me is offline   Reply With Quote
Old 06-25-2002, 11:20 AM   #5
speedmiser
Check the fuel pressure. In my opion, 32 is way to low to set the fpss. Mine is set about 2 pounds below my fuel pressue (43 on a fuel system that runs at 45psi)
Your fuel pressure could be dropping to the mid to low 30's and causing a lean condition which will cause surging.
Might not be the problem, but it would be worth the time to check it out.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
[This message has been edited by speedmiser (edited June 25, 2002).]
__________________
1968 Camaro Project w/ LT1 383 and S-Trim
There has been an alarming increase in the number of things I know nothing about!!!
speedmiser is offline   Reply With Quote
Old 06-26-2002, 07:21 AM   #6
Racing
Surging like the one described in always lack of nitrous.
Read the ideas all over and go from there.
__________________
DVC-2001.Racing
482 cubes of fogger injected thunder in a 71 z-28.
Viking thunder
Mail me at
racings email
Racing is offline   Reply With Quote
Old 06-27-2002, 02:16 AM   #7
John Denver
Junior Member
Sounds like your nitrous filter is clogged. If your pressure is OK then that may be the problem. Also check your jets it definately sounds like a nitrous delivery problem.
__________________
Don't let the name fool you!!
John Denver is offline   Reply With Quote
Old 06-27-2002, 10:37 PM   #8
KTamez
KTamez's Avatar
Are you using a 46N/40F in EACH nozzle?
This seems mega rich to me. FYI this about a 150-175hp system (By Nitrous Jet Diameter), and you're using big time fuel (Probably enough for 200-225hp of Spray). Could be a large part of the problem.....
Also note that if your pump doesn't have enough VOLUME to support the jetting you're using, the PRESSURE could drop dramatically, causing the surging problem from the FPSS.....
Your 40/30 jet combo works out to ~125hp, with still an overly rich 175hp worth of fuel, but your pump, may be able to keep up with this load, and so the FPSS isn't pulsing.
Try leaning things out to a 40N/24F and 46N/28or31F.
Just some ideas for ya.
All standard disclaimers apply!!!!!!!
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
[This message has been edited by KTamez (edited June 27, 2002).]
__________________
Kurtis Tamez
Turbocharged 70 Nova SS
90 Mustang SSP Coupe
07 Jeep grand Cherokee SRT8
KTamez is offline   Reply With Quote
Old 06-28-2002, 07:42 AM   #9
LT1S10
Yes, I'm running that jetting in each nozzle. I agree it is probably way to fat. I'm using the jetting recommended by NOS. But, when looking at jetting for a TNT dual nozzle kit it is around the size you suggest on the fuel side. I need to just put it on the dyno and see what A/F I'm getting, etc.
Thanks everybody for your help.
Mike
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
