Do I HAVE to go colder plugs with nitrous?
Old Jun 22, 2002 | 12:37 AM
Love Potion #9's Avatar
Question Do I HAVE to go colder plugs with nitrous?
What will happen if I stick w/the ACDelco plat plugs on a 75 or 100 wet shot?
Old Jun 22, 2002 | 02:38 AM
roofo's Avatar
Red face
BOOM!I guess.I hear it's not good.Plugs will melt I guess.
[This message has been edited by roofo (edited June 22, 2002).]
Old Jun 22, 2002 | 09:09 AM
RacinLT1's Avatar
If you stick with the platinum plugs on nitrous,you will melt the platinum off the plugs and go from stock gap,to twice the stock gap.
DO NOT use platinum plugs,dont have to go colder. But each car is different.
Dirk
1997 TA A4, Finally Legal to 10.00 (now i just gotta get it to go that fast)
The RacinLT1
RacinLT1 pic's
Old Jun 23, 2002 | 03:02 AM
Question
Will colder plugs effect the performance of the car when I am not runnin the juice thru it?
Old Jun 23, 2002 | 07:17 AM
Derrick Redd's Avatar
Definetly don't use platinum plugs. If you go 1 or 2 heat ranges cooler it shouldn't affect you NA. I run 2 heat ranges cooler and my car runs great NA and on the dope.
<A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4
LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope
11.03 @ 125.53 1.61 60ft.
7.08 @ 99.05 1/8 mile</A>
1984 Mustang L
92' 5.0 roller motor, T5, etc.
14.03 @ 100.51 with a spinning 2.29 60ft.
[This message has been edited by Derrick Redd (edited June 23, 2002).]
Old Jun 25, 2002 | 12:08 PM
asianice25's Avatar
Cool
I would change the plugs as well, i run regular delcos at the moment, but im changing to NGK TR-6's when i put my headers on(a month or so). However, if you spray 75 on stock plugs you shouldn't have a problem, because its the ignition/ntrous combo that screws you. itll melt the electrode right off, but the stock ignition isnt hot enough to do that, unless your case is extreme.
Scott Parkinson
2001 Sunset Orange Z-28
SLP Loud Mouth, K&N, Mass Air, 160 Thermistat, Power Programmer, All aftermarket suspension/braces, 8.5mm Plug Wires, 125 hp Shot. Runnin low 12's all day.
Old Jun 26, 2002 | 01:15 PM
n2oTransAmLT1's Avatar
FWIW..I am running a 125hp shot on my internally stock LT1 with lots of bolt ons and REGULAR SPLITFIRE PLUGS. Stock heatrange, just gapped smaller and have never had a problem through 80lbs of nitrous.
camaroguy50613
May 27, 2016 09:00 AM
Mar 13, 2016 03:39 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
bandit383lt4
Dec 21, 2014 09:12 PM
