N02 Bottle Overheating Question??
Old Jun 13, 2002 | 04:24 PM
XKnightRider's Avatar
Question N02 Bottle Overheating Question??
First off I live in AZ and it's that time of year where it's hot here!
At what PSI will the blowoff tube/safety valve pop at? If it does pop will it unload the whole bottle or just enough to get it back to a safe pressure?
Guys in hot climates: Do you keep your bottles in your car or pull them out in the hot time of the year?
Old Jun 13, 2002 | 07:10 PM
RacinLT1's Avatar
I think the relief pops at 1500 psi,never had it happen,so not sure.
Once it pops,the whole bottle is emptied. It's a small piece of foil,thats it.
Dirk
1997 TA A4, Finally Legal to 10.00 (now i just gotta get it to go that fast)
The RacinLT1
RacinLT1 pic's
Old Jun 13, 2002 | 08:47 PM
94Z28DOJ's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RacinLT1:
</font>
I thought it was 3000 psi.
Old Jun 13, 2002 | 11:05 PM
RacinLT1's Avatar
my friends NX relief popped @ 1500 psi,i think 3k is max pressure of the bottle.
Dirk
The RacinLT1
RacinLT1 pic's
Old Jun 14, 2002 | 10:05 AM
Question
Once it does pop is the bottle messed up? Do you have to get a new valve?
Old Jun 14, 2002 | 11:10 AM
PONYEATER's Avatar
All you have to buy is a new disc. Make sure you only put one disc in! A certain idiot gained fame by putting two in and having the bottle explode.
Arron Spitzer
Musclecar Technologies
Honest answers........LOW PRICES!
Old Jun 14, 2002 | 01:07 PM
1989gta's Avatar
on my nx kit there is a small metal disc in the blowoff valve fitting that says 3000 psi on it. once the disc pops all psi is gone then you replace the disc and fill it again.
here is the nx link to the part then goto bottle accesories and then bottle safty fittings.
http://www.nitrousexpress.com/welcome.htm
[This message has been edited by 1989gta (edited June 14, 2002).]
Old Jun 15, 2002 | 12:39 PM
iwon's Avatar
my buddy has a valve that lets out, only enough to lower the psi.he made it,
Old Jun 21, 2002 | 12:09 AM
Luvenit's Avatar
The blow off valve goes at 3000 psi and i believe the bottle itself would fail around 4000 - 5000 psi.
94 Z28 A4(bottlefed)
calaban
May 18, 2020 06:43 PM
warmeck
Apr 16, 2015 05:50 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
