RPM switch install question.
Old Jun 12, 2002 | 12:29 PM
F-16 CHIEF's Avatar
Question RPM switch install question.
Is the install guide on midnightautowerks.com page for the window switch the same for a 96? It says the white wire, #10 is the wire to install it with from the computer. Mine is a 96, but the install is for a 2000. Thanks!
96 Formula M6, FLP's, SLP CAI, Cut-out, Flowmaster muffler, HPP+, Pulleys, Hurst Shifter, Taylor Wires, GMS STB, LCA's
Old Jun 18, 2002 | 11:09 PM
F-16 CHIEF's Avatar
Maybe my first question was a little vague. All I need to know is where does the white wire on a MSD window switch go to on a LT1? Thanks!
Old Jun 20, 2002 | 08:15 AM
Mtrhds94Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by F-16 CHIEF:
Maybe my first question was a little vague. All I need to know is where does the white wire on a MSD window switch go to on a LT1? Thanks!</font>
Well if you have an MSD box, use the tach output [a plug hole on the box]...
Or, in my 94Z factory manual, the wire for 'tach output' is '#13' [a white wire] of the 'red' PCM connector [ not sure if YOURS is though.. and not sure if that's the wire you seek?]
94Z28 KN FIPK CAI,Meziere Electric Water Pump, MSD 6A,MSD Blaster Coil,Moroso 8mm Wires,March 20%Underdrive Damper w/10% OD alt pulley,Ported/descreened MAF,A4 First Gear Mod,Jamex STB,1LE Alum DS,1LE Trans Mount,Powerslots w/KVR pads, T/A rear cover,TB Bypass,160* Stat,Airfoil,150MPH Speedo,Mobil 1 Synthetic Thruout,3 to 5 Spkr Bose
[This message has been edited by Mtrhds94Z (edited June 20, 2002).]
Old Jun 20, 2002 | 08:20 AM
F-16 CHIEF's Avatar
Yes, that's the wire I seek. I'm just trying to hook up my window switch. I have it hooked up except the white wire. I didn't know to go to the negative side of the coil or go to the #10 wire on the computer. I got the #10 wire idea from the midnightautowerks.com page about how to install a window switch. Thanks!
alex5366
Feb 17, 2015 09:07 AM
Jan 23, 2015 01:13 PM
edman
Jan 22, 2015 02:45 PM
Deadbolt24
Jan 19, 2015 01:29 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
