Old 06-17-2002, 08:25 PM   #1
rje
Send a message via ICQ to rje
Post N2O activation ?
I am planning on spraying a 125 shot this weekend and was wondering if the way I have things setup is safe? I only us a micro switch for WOT activation and want to know if the system will be activated to soon like this. I've sprayed a 75 shot with no problem, but what about the 125 ? I ususally stall against he converter to about 2200 rpms then when the light goes on I go to the floor. I figured that with my 4000 converter I should have plenty of rpm before the n2o comes on, but what do you guys think?
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.57 60ft 7.31 @ 94.2 mph 11.51 @ 115.47 mph (75 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
__________________
94Z 383 LT1, AI 200cc Dominator LT1 heads and intake,1.75 Hooker LT's,58mm TB,Jesel shaft rockers, 42# injectors,Bullet soild roller camshaft,Powerglide/5400 TC,Moser 12bolt/spool/5.14's,tuning by Alvin@PCMforless Hoosier 30x10.5x15 radial slicks,raceweight 3300lbs.
1.32 60ft, 4.15 330ft 6.55@101 mph 1/8
rje is offline   Reply With Quote
Old 06-17-2002, 09:11 PM   #2
94Z28DOJ
94Z28DOJ's Avatar
It shouldn't come on, but you can get a window switch just in case. Hope you got some good tires because 125 lot funner then 75.
94Z28DOJ is offline   Reply With Quote
Old 06-17-2002, 11:43 PM   #3
rje
What I meant was that I didn't want the n2o to come before I got the necessary rpms so as not to bend a rod. As for tire, my 27x11.5x15 hossier qtp's hook quite well tot he tune of 1.59 on the motor.
Randy
__________________
Old 06-18-2002, 12:27 AM   #4
Z28ROC
Z28ROC's Avatar
I used to spray without a window switch on a stalled LT1. But it only takes one low RPM activation to cause a big boom! I personally would never spray without a window switch.
Mario,
White 94 Z28
Yeah I got a few mods
Video
__________________
Mario,White 94 Z28
Video
Black 87 IROC-Z
04 KFX 400
Z28ROC is offline   Reply With Quote
Old 06-18-2002, 07:44 PM   #5
gb95zconv
Send a message via ICQ to gb95zconv
If the engine should happen to stumble for some reason you could have a big problem. Thats less likely with an auto but it still is a real possiblity. Get a window switch and no worries.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
__________________
Greg
95 Z28 conv M6 383 ci (SOLD)
Georgia FBody Association
gb95zconv is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
