How can I tell if a subwoofer is good or bad?
Old Sep 12, 2003 | 02:09 PM
KillerTA's Avatar
I don't have the ability to hook it up to a car stereo, so is there another way I can tell?
Old Sep 12, 2003 | 02:20 PM
LS1 RULZ's Avatar
Do the "pop" test with a battery. Connect it to a battery for just an instant to see if the cone moves. If it pops you have continuity in the voice coil.
Old Sep 14, 2003 | 09:11 PM
KillerTA's Avatar
What kind of battery? Thanks!
Old Sep 14, 2003 | 09:16 PM
Eric H's Avatar
I've always been told an "AA," "AAA," or a 9V will work. I've always used an AAA.
-Eric H
Old Sep 20, 2003 | 01:39 AM
rage366's Avatar
assuming that the sub works, you can check how much use it has by pushing down on the center of it to see if it goes down really easily or not....
typically, if a sub is used with lots of power, the foam around the sub will get weaker and become easier to push down...which isnt good.
Old Sep 20, 2003 | 05:39 AM
LS1 RULZ's Avatar
This is not an accurate way to determine the amount of use a sub has had. The stiffness or looseness of the speaker's suspension (foam/rubber surround and the spider) is different for all speakers. Just becuase one is loose doesn't mean that it's shot.
Old Sep 20, 2003 | 12:00 PM
rage366's Avatar
i didnt say shot...my pioneer 12 used to be really stiff when i bought it 3 yrs ago...but now, it's much looser, simlpy because it becomes more flexible.
newer subs that i've seen dont use the foam...they're transitioned to using the rubber surrounding.
with subs that have the foam type surrounding, i believe this is a simple tool to guide a person in the right direction.
there really isnt a sure way of knowing what a sub has been through. simply because a sub has current right now, it doesnt mean that it will in 5 minutes.
only way to be sure is to know exactly what the sub has been through...and even then, it's a piece of electronics, so it can burn out anyway.
Old Sep 20, 2003 | 02:39 PM
rthompson's Avatar
THere are still a ton of subs out there that use foam. Most of the high excursiuon subs have foam because foam is better suited to keeping the VC centered and it is less prone to pucker at high excursion. When you have a high excursion sub it is extremely important to have a linear stroke because of scraping issues.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
mattszm6
Dec 14, 2014 07:09 AM
