96 Red t-top fromula for sale cheap!
Old Sep 12, 2003 | 01:07 PM
VINCELEE123's Avatar
ok ive got a 96 formula for sale, as of right now it doesnt run.
It has a 355 forged pistons,magnaflexd shoppend rods, nodular iron crank, nitrous rings, all new bearings,freeze plugs arp rod bolts. It has a comp 306 cam, coated hooker lts, stock heads, ported lt1 intake, 24lb svo injectors, pcm programmed for cam and stage II heads, new distributor, new plugs, tayor OVC wires
the transmission was built for nitrous, completely redone, new everything and a matching 2800 nitrous convertor
the engine and tranny has less than 200 miles on them.
the problems with the car are, the fuel rail is broke, you would need a new one, cam was installed one tooth off, it would need to be pulled and re installed, the car has no roller rockers right now, and it needs a cold air kit and a y pipe for the longtubes
this is what it would need
150$ for gasket
50$ for fuel rail
100$ for used cold air kit
169$ for ypipe
150$ for good rockers
car also has a new battery, harden pushrods,guild plates,air foil,
thats about it. Red T-top, gray cloth, factory cd, power everything,
4000$
Vince
Old Sep 14, 2003 | 12:31 PM
SloTexanTA's Avatar
Wish I had the money, but good luck. Have you posted this on htownracing.com or houston-f-body.org?
Old Sep 14, 2003 | 12:53 PM
no
most of them are just kids, and i dont want any local street racers to know what i have if i decide to keep it.
Old Sep 14, 2003 | 06:56 PM
SloTexanTA's Avatar
True, and they aren't just kids, they're stupid kids. If you don't mind me asking, why aren't you keeping it?
Old Sep 14, 2003 | 08:58 PM
street racing is dead. every time i make up my mind on what i want to do with i always change it.
to much money and time, i figure this is an easy way out.
Vince
Old Sep 15, 2003 | 09:26 PM
SloTexanTA's Avatar
It seems like an easy way out, and that's what I said when I sold my Camaro. But it always pulls you back in, that's how I ended up with the TA. Good luck, hope you get what you want.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
Collector Car
Dec 17, 2014 01:12 PM
The Seer
Nov 20, 2014 06:32 AM
