rear end
Old Sep 12, 2003 | 01:03 PM
nads70's Avatar
rear end
I just picked up a posi rear out of a 79 T/A w/ 2.41's. I've never worked on one and know nothing about them, ( the smell of gear lube makes me sick!). I figured I could just change the gears and be done, but now I'm finding out otherwise. Whats the highest (numerically) gear I can run with the carrier thats in it, I want 3.73. Also, someone told me that theres some kind of spacer made so I can change the gears to 3.73 without changing the carrier.
Old Sep 12, 2003 | 08:35 PM
angel71rs's Avatar
The break is 2.56 down, 2.73 up. You can buy a ring gear spacer so you can use a 2.73 up ring and pinion on your carrier. Here is one source:
http://tomsdifferentials.com/cat41.htm
Old Sep 13, 2003 | 07:07 AM
nads70's Avatar
thanks
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
