Help With mystery motor...
Old Sep 9, 2003 | 11:31 PM
92Zx28's Avatar
This is a v/8 chevy motor do not know the engine size for sure. The number on the block were T0611ctu the 11 may just be a divider between T06 and ctu?.It was removed from a 1974 1 ton truck.The odometer read 98,000 miles,I believe that is the actual miles.Four barrel carb. I was told it is a 400 cid.
This is what i was told about the motor...it could make a good rebuilder for my project, any info you could give me to shed light on this subject is greatly appreciated...
Old Sep 9, 2003 | 11:36 PM
kacy's Avatar
check to see if it has 3 freeze plugs per side if it does then its a 400 there is also something about the balance its either in the balancer or the fly wheel i think if its externally balanced its a 400 someone correct me if im wrong
Old Sep 9, 2003 | 11:57 PM
jg95z28's Avatar
T 06 11 C TU
T = Tonawanda, NY
06 = Month
11 = Day of Month
C = Vehicle Type (in this Case... "CAR")
TU = Engine ID Code
So its definitely not a "Truck" block.
According to two sources I checked... CTU was used for 1970 350 LT-1 "Corvette". (H.E.I., spec high perf, m/t LT1 370HP to be specific.)
However.... (see next post)
Old Sep 10, 2003 | 12:04 AM
jg95z28's Avatar
Alright... sorry for getting you hopes up...
CTU was also used on 1975 400 cid 175hp 4bbl LT4 .
http://www.chevy-camaro.com/chevy-ca...ffix-codes.asp
Old Sep 10, 2003 | 12:44 AM
92Zx28's Avatar
good lookin out. Its a 400 SBC LT4...Heh obviously not the same LT series as current...?
Something i should invest in?
Let me know...
Old Sep 10, 2003 | 07:52 AM
Jeff H's Avatar
CTU shows up as a 1970 Corvette LT1 engine or a 1975 400. You might want to get the casting date off the block just to be sure, but if it was in a 1974 truck then it probably is the 400.
Old Sep 10, 2003 | 08:59 AM
jg95z28's Avatar
However, "CTU" is not a truck block. So its definitely not the original motor. It could be a '75 replacement, but its worth checking the casting dates... just in case.
Old Sep 10, 2003 | 07:23 PM
SDAKOVIC's Avatar
if possible, measure the bore and the main journal size. also, 400's have steam holes between the cylinders and yes, they are externally balanced.
Old Sep 10, 2003 | 10:12 PM
angel71rs's Avatar
Balancer on a 400 will have a scalloped out section on the outer ring. Check the block casting #. It is on the back of the engine on the bell housing extension, behind the oil pressure fitting.
Then check the number at mortec.com. If it ends in 509, it's a 400, like the one in my 71. But there are more 400 casting #'s.
Old Sep 11, 2003 | 06:37 AM
BIGBADBOWTIE's Avatar
Not all 400 smallies have 3 freeze plugs per side. My 509 casting 400 has 2 per side with a provision for a 3rd.
Yes all 400's were externally balanced.
Just wanted to add that Information.
Old Sep 12, 2003 | 12:05 AM
92Zx28's Avatar
pics of engine...
heres a few pics of the engine....
http://www.bgom.net/engine
Old Sep 13, 2003 | 11:15 PM
92Zx28's Avatar
check those pics, should help ya be sure...
Old Sep 14, 2003 | 12:02 AM
kacy's Avatar
wellm i didnt see a real good pic of the balancer and only 2 freeze plugs and the way that alternator mount is set up i would guess that its probably not a 400 theres still a chance it could be as everyone else said either measure the bore or check the other #s you didnt put on the bored
Old Sep 14, 2003 | 02:11 AM
jg95z28's Avatar
Woah! Are those not Corvette exhaust manifolds?
Ummm, definitely check the castings because that looks like it might be a LT1.
Old Sep 14, 2003 | 08:26 PM
angel71rs's Avatar
I think you can just make out the cutout portion of the balancer, but it's blurry. Not all 400's had 3 freeze plugs. The two 509 casting 400's I have built had only two.
