Is this in any way remotely possible? pcm chip related
Old Sep 9, 2003 | 10:14 PM
thewinner's Avatar
Is it possible to socket some sort of Y into the pcm then have 2 chips in order to store 2 pcm programs on the car, and have the ability to switch them over when the car is off?
This would be badass if it could be done, have a daily driven program and a program for race gas with more timing, boost, etc....
Lemme know guys!!!!
Old Sep 10, 2003 | 12:52 AM
m0nk's Avatar
I dont see why you would want to do this when you can just have reprogram it for racegas, then after the track, put pump back in, and take another 3 minutes to reprogram. Or am I missing the point
Old Sep 10, 2003 | 03:34 PM
DOOM Master's Avatar
Is it possible? I suppose it is possible, but the difficultly in doing so would be not worth it. Since you would actually need to have two Y sockets and 4 chips (there are 2 FLASH chips on the PCM) and then something to switch between chips made so you can easily change them (from the inside of the car, I'm assuming). A lot of work, if you ask me, and it would take a lot of custom work. Just reprogram the PCM when you need to, it only takes 3 to 5 minutes to switch programs.
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
whitehooptie
Jul 22, 2015 10:25 PM
