Cylinder Heads !
Old Sep 9, 2003 | 08:24 PM
shwine617's Avatar
Cylinder Heads !
I am buying a holley stealth ram with 24 lb injectors, and a 58mm throttle body.
what type and size heads would be the best to match ?
thanks
Old Sep 9, 2003 | 08:29 PM
doug791's Avatar
wow you left out a bunch of important details mainly all of them
First of all what do you want your power band to range from ie
0-5000....2000-6500
also how much power are you looking reach?
AlSo how much money do you have to spend
if money is no object get a set of afr either 190's or 195's those are some of the best you can buy.
Old Sep 9, 2003 | 08:33 PM
Black6SpdTA's Avatar
AFR's =
Doug pretty much got it all. Do you know the specs of the "performance cam" you have?
-Rippin
Old Sep 9, 2003 | 08:34 PM
shwine617's Avatar
i was thinking about getting the afr 195 heads, I heard they were pretty good, I want to end up near 450-500hp when I am done.
Old Sep 9, 2003 | 09:01 PM
doug791's Avatar
if you can afford afr 195's i dont believe there is anything better. If you have a cam to match the power band and the stealth ram can keep up you shouldnt have a problem hitting 500 hp. just make sure your tranny/rear end/engine internals can handle it before you do hit those kind of numbers.
Old Sep 10, 2003 | 08:37 AM
aklim's Avatar
AFR 190 or 195
Old Sep 10, 2003 | 08:55 AM
doug791's Avatar
Originally posted by aklim
AFR 190 or 195
eh both are great but im preferential to the powerband of the 195's theyll let you pull a little higher.....not sure if 190's would be better suited to the stealth ram? If you called afr im sure they would hook you up with the right setup....btw as soon as you do buy some afr's im stopping speaking to you out of jealousy. i know how much you care...
Old Sep 10, 2003 | 08:07 PM
shwine617's Avatar
yea, i am normally the person who doesn't have the money to buy these kind of things, but I am going to the englishtown swap meet and selling everything I own. which is 13 mopeds, 2 motorcycles, 2 go karts, 2 minibikes, and a bunch of other crap, so i hope that will give me enough for alot of nice parts.
Old Sep 10, 2003 | 09:05 PM
chevyman502bb's Avatar
mind i ask why in the god damned **** you own 13 mopeds?
Old Sep 11, 2003 | 12:12 PM
shwine617's Avatar
lol, i figured someone would ask,
well when i turned 15 ,mopeds were really popular by my house,so i wanted to buy one and i got one and fixed it, then i found others for cheap and fixed them too. most of them are ones my friends couldn't fix , so i took them off there hands and fixed them. the collection kinda just grew bigger and bigger. now that i have a motorcycle and a camaro i stopped collecting them.
now i just wanna get the hell rid of them.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
