Lashing valves with feeler gauge?
Old Sep 8, 2003 | 06:57 PM
Mullet Z28's Avatar
How is this done?
Do you just stick in the feeler between the rocker tip and valve stem and tighten? I assume it doesn't matter whether or not the lifter is at the base of the cam, since lash should be the same regardless of cam phasing.
I was going to do the old Exhaust-Open/Intake-Close, but since this is a solid roller, the feeler gauge should be more precise.
Old Sep 8, 2003 | 07:03 PM
Damon's Avatar
No. Gotta be on the heel of the cam when setting lash, not on the ramp or the nose. Every valve.
If you set the engine on TDC, compression stroke (not exhaust stroke) of #1 you can adjust both valves on that cylinder, Then turn the engine 90*clockwise, adjust #8, 90 more degrees and do #4, etc. through the entire firing order- 18436572, assuming this is an LT-1 or older motor. LS1s have a different firing order.
Old Sep 8, 2003 | 07:12 PM
Mullet Z28's Avatar
Thanks for the quick reply.
Sorry admins, I posted this in the wrong section!
Old Sep 8, 2003 | 11:41 PM
JWINN's Avatar
Re: Lashing valves with feeler gauge?
Originally posted by Mullet Z28
How is this done?
Your correct if you adjust your valves using the EO/IC method. Adjust the valve that is closed and on the base circle or back side of the cam for each firing location.
For example what ever cylinder you choose makes no difference but lets say 1 cylinder when the exhaust is opening adjust the intake valve with the feeler gauge and so on with the theroy EO/IC. Just make sure the valve train is hot because the clearance wil be off if the valves adjusted cold and then they heat up. This EO/IC methode will work no matter if its a solid roller which would require the use of feeler gauges or flat tappet.
Good Luck,
Old Sep 10, 2003 | 01:27 PM
Z28SORR's Avatar
It's pretty hard to get the engine hot if it's the first time you've set the lash.
Most cam manufacturers give you both hot and cold specs.
Old Sep 12, 2003 | 06:25 PM
Damon's Avatar
If they don't give you cold lash specs then just set it at the hot lash for initial startup/break-in. It doesn't move THAT much from cold to hot. Redo it later when you get it running reasonably well. Besides, it's gonna open up just a smide anyway when the fresh vavletrain gets broken in (maybe a half hour of run time).
Old Sep 16, 2003 | 11:26 AM
nosfed's Avatar
If they don't give cold lash specs, just add .002 to each side. And going down the firing order is much faster than the other method. |
You know that with the feeler gauge in between valve and rocker, you don't actually tighten the lock, just snug it until you feel light tension between the two. Then lock it, and check with feeler again to make sure you didn't miss it.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
FredM
Apr 10, 2015 02:56 PM
QuickSilver02
Apr 7, 2015 11:12 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
