Old 07-19-2002, 03:10 PM   #1
burnNrubber
New Member
Post tranny ?'s
i own a 91 rs v6 camaro i would like to put a 350 in it but i need to know if the transmission will fit up or will i need a new one... i am also curious what the name of the transmission is... if the tranny doesnt fit up what all would have to be done to fit a 4 speed muncie up to my car with the 350... any help at all will be appreciated.. thankyou
burnNrubber is offline   Reply With Quote
Old 07-19-2002, 06:43 PM   #2
MustangEater82
MustangEater82's Avatar
Send a message via AIM to MustangEater82
I am 955 sure its a Th700R4. I think they are interchagneable but you will need a different bell hosuing the stock bellhousing will not fit.
as for the muncie 4-speed, I would check out third gen tech they might be the ones that have done it.
i know there are kits to hook a T-56 6-speed to a 350 in a 3rd gen.
And jsut in case you already didn't know, the T5 5-speed si not storng enough to hold up agians th power of a 350.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
AIM: MustangEater82
__________________
-2007 Pontiac G6 Sedan (Former cars, '85, '94, '00 Camaros, '92 5.0)
Quote:
Originally Posted by ACE1252's Keeper View Post
Yes, and while I'm all for swallowing, I draw the line at yogurt flavored Pepsi.
MustangEater82 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
