Old 07-12-2002, 07:11 PM   #1
MississippiMaro
New Member
Exclamation Front Shock Install....Spring Compression Tool
Hey Guys, does anyone out there who has done the front shock replacement know if the "strut spring compression" tool from autozone will work on our cars. I was looking in my chilton's and it shows a completely different spring compression tool. I just got my z-28 T/O Shocks from SLP and i'm itching to get them on.
1993 Camaro 3.4L A4 Purple Pearl Metallic
Bone Stock except for K&N Filter and Accel Wires
__________________
MississippiMaro is offline   Reply With Quote
Old 07-19-2002, 03:16 PM   #2
burnNrubber
New Member
hey man im pretty sure you can just use the compression tool but.. if you want you can call the gm main office and they should be able to tell you if you want the number it's 1-800-222-1020 that way you know for sure... and you won't get halfway into the project and find out someone was wrong.. bye the way.. have you seen a black gmc sierra running around ridgeland and madison with white stripes and ss350 stickers on the side.. just curious..
burnNrubber is offline   Reply With Quote
Old 07-19-2002, 04:32 PM   #3
Scammper
Send a message via ICQ to Scammper Send a message via AIM to Scammper
yep that tool from Autozone worked fine for me... just be patient... seems like you have to compress it forever till it becomes loose, but it does.
Good Luck
1995 Camaro 3.4 M5
Custom Cold/Ram Air
Flowmaster 80
MAC progressive springs
17x9 ZR-1 Replicas on the way...
and some cool electrical stuff, my 'camaro' lights up... check it out at:
http://scammper.fbody.com
__________________
2001 SS & 1995 3.4
Scammper is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
