head surface question
Old Sep 5, 2003 | 07:55 PM
jgeorger's Avatar
I just got my heads back from my machine shop. I noticed this small imperfection that seems like a raised split... maybe like the cutter caught and lifted the metal a little. Please take a look at the following pics and tell me if this is something I should be worried about.
http://home.comcast.net/~jgeorger/Pics/DCP_1340.JPG
http://home.comcast.net/~jgeorger/Pics/DCP_1335.JPG
Thanks,
Joe
Old Sep 5, 2003 | 09:12 PM
OldSStroker's Avatar
It looks like the cutting edges, or at least one of them on a multi-tool cutter loaded up a little. If you can remove little pieces of aluminum it could be a problem. If not, it doesn't look bad.
You get better sealing to the head gasket with a slightly rough surface than a smooth polished surface.
You might take a piece of 220 or so paper and run around the edge of the chambers just to eliminate any sharp edges or burrs which could burn or break off.
If you are concerned, take them back and ask.
How much was milled off?
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
thenewkid
Nov 27, 2014 09:41 AM
Brian Demeter
Aug 21, 2002 02:07 PM
