What cam are you nitrous guys using?
Old Sep 5, 2003 | 10:48 AM
john97z28's Avatar
I have a Compucar kit with the 150 hp jets. The car is mostly a daily driver but I shot of the N2O 1-2 times on weekends. I will be installing LT4 ported and polished heads and intake, 1.6 RR, hydrolic lifters, 30 lb SVO injectors and new fuel pump. With those mods what cam do you think I should use? Someone recommended the XE230-236 to me.
Old Sep 5, 2003 | 06:36 PM
12Second3rdgen's Avatar
That cam sounds about right, just make sure it is ground on a 112 LSA. 230/236@.050 is about as big as I would go on a daily driver.
Old Sep 5, 2003 | 10:44 PM
TMDZ28's Avatar
how about 224/230?? is that sounds too small?? i have to pass smog here in stupid cali
Old Sep 5, 2003 | 11:03 PM
93formula's Avatar
224/236 xe here emmisions legal with some tuning
Old Sep 6, 2003 | 12:57 AM
TMDZ28's Avatar
cool....thanks
Old Sep 8, 2003 | 10:26 AM
t-trimz28's Avatar
Why would he want a 112 LSA? You will be blowing all of your nitrous out the exhaust. You will need it on a 114 LSA. I have a custom Lazer grind that really likes the bottle.
Old Sep 8, 2003 | 03:48 PM
112 and 114 are generally both acceptable lsa's for nitrous and blower grinds. Hell I know a lot of people who run large amounts of nitrous on 110 LSA's and still see good results.
Old Sep 8, 2003 | 04:14 PM
Nostang 96z's Avatar
Correct me if I'm wrong but I thought a tighter lsa angle such as a 110 or 112 was better suited for higher compression nitrous engines in order to bleed off a little bit of the cylinder pressure and a 114 or higher lsa was better suited for a lower compression engine that relies on a bigger hit of nitrous in order to keep the cylinder pressure up.
Later
Matt
Old Sep 8, 2003 | 04:26 PM
fastcamz28's Avatar
So, would a Hot Cam and 100-150 shot (wet) be ok? This may not be the optimal combo (I already have the Hot Cam installed), but it's what I have to work with.
Thanks!
Old Sep 8, 2003 | 10:20 PM
Rasta's Avatar
There are probably many here running hot cam that can chime in and tell you what they gain is on nos. Im sticking with my lt4 hot cam and the NX kit I just bought should arrive friday. Ill
post my gains in this thread after I install the kit.
Good luck, Cliff
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Red97LT1
Aug 7, 2002 05:45 PM
