Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
September special of the month - Strange 12 bolts!
Old Sep 2, 2003 | 08:30 AM
tbyrne's Avatar
Our September special of the month is for the Strange 12 bolt rearends. Sale pricing through 9/30 is -
PRG210
Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73 or 4.10
$2139.99
PRGOP8
Upgrade to US/Strange 33 spline Super strength posi-unit (w/o reluctor ring - ABS on side of pumpkin)
$145.00
PRGOP14
Upgrade to US/Strange 33 spline Super strength posi-unit (w/reluctor ring - ABS on top of pumpkin)
$145.00
PRGOP10
Upgrade to aluminum support cover
$115.00
gmbbp
Options: Purchase brake backing plates to be built into rear (1998+)
$229.99
(you can either purchase the backing plates listed above or send yours in when the rear is ready to be built).
More info can be found off the opening page of our website .Orders can be placed online or by calling 1-877-4-TBYRNE.
Tom
Old Sep 4, 2003 | 01:58 PM
9SECONDLX's Avatar
is this a direct bolt in. what type of modifications will be needed to make fit and what other hidden expense are there? example new drive shaft? torque arm?
thanks
Old Sep 5, 2003 | 08:08 AM
tbyrne's Avatar
The Strange rearend is a bolt in with no other mods required for the LT1. Just swap your brakes and connect your stock driveshaft and torque arm.
Old Sep 11, 2003 | 09:53 AM
tbyrne's Avatar
Still going
Old Sep 16, 2003 | 10:19 PM
SS MPSTR's Avatar
Left you a voicemail today, Tom.
Old Sep 20, 2003 | 07:14 PM
tbyrne's Avatar
A little over a week left for this one!
Old Sep 29, 2003 | 11:47 PM
Black95Form's Avatar
What is the time frame from ordering to actually receiving the rear end?
Old Sep 30, 2003 | 03:41 PM
D James's Avatar
With these units, can I expect to hear any gear whine, cause I've heard of some aftermarket 12 bolts having some pretty bad whine, just not sure if its strange rear ends.
Old Sep 30, 2003 | 07:37 PM
tbyrne's Avatar
Strange has been shipping about 3-4 weeks after the rear is ordered. A few have been quicker but it's safer to plan for 3-4 weeks.
Most aftermarket gears and rearends have some gear while. I've driven many cars with the Strange rearend don't fine it to be to bad. Some have been so quiet you would think it was stock.
This special is wrapping up today but we will accept orders through tomorrow afternoon.
Tom
www.tbyrnemotorsports.com
maybe2fast
Mar 16, 2015 09:45 AM
SABLT194
Aug 21, 2002 07:45 PM
Gino/98TA
Aug 7, 2002 11:16 PM
Sixer-Bird
10
Aug 4, 2002 04:07 PM
SABLT194
Aug 3, 2002 09:33 AM
