Old 07-01-2002, 12:20 PM   #1
68 Camaro Conv
Member
Post Rearend info
I currently have an 8.2 open with 2.73 gears. What I would like is posi 3.42.
1. Is this rearend strong enough to just put an eaton posi in it or
2. should I locate a different rear 8.5 or 12 bolt to put in it.
Anyone have any good sites to order rearends from.
__________________
68 Camaro in work, 94 camaro v6 no mods
68 Camaro Conv is offline   Reply With Quote
Old 07-01-2002, 04:17 PM   #2
JeffT
check out http://www.moserengineering.com/ They have bolt in 12 bolt and 9" rears for 1st gens. You should be able to get a better deal $$$ by purchasing it from a vendor like TByrne or Thunderracing.
JeffT is offline   Reply With Quote
Old 07-02-2002, 08:41 AM   #3
BIGBADBOWTIE
It all depends on what your going to do with it. I mean if your gonna throw on sticky meats and launch off a transbreak or dump a clutch on a 4 speed then the 8.2 is not gonna hold. If the car is gonna be a cruiser with an occasional red light street fight then the 8.2 should be Ok. I had an 8.2 with 4.10 gear in my 67 for 2 years with a 4 speed and a pretty stout 350. I never had any problems with it until about 5 visits to the strip with slicks. I ended up shooting the ring gear out back cover.
If your gona beat it find a big ten 8.5 or 12.
Thas Just My opinion.
Ray
__________________
1978 Z Camaro
355 roller with GO gas
Ray
BIGBADBOWTIE is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
