Old 06-28-2002, 12:00 AM   #1
talos
talos's Avatar
Post exhaust piping
i have a stock 350 motor, with long tube headers with 3" collectors, true dual, is it ok to run 3" all the way or whould i get 2.5"???
__________________
"Lets have a sexy party"
talos is offline   Reply With Quote
Old 06-28-2002, 01:23 AM   #2
81formula'bird
Send a message via Yahoo to 81formula'bird
run the 2.5 " inch exhaust the 3" won't provide enough backpressure for a stock engine, but if you plan on building it up just go to 3 inch so u wont have to buy a new exhaust system later and just sacrifice some power now
__________________
1990 Cougar XR7 supercharged
1991 S-10, 4 banger
new project.
81formula'bird is offline   Reply With Quote
Old 06-28-2002, 01:54 AM   #3
talos
talos's Avatar
how is it bending 3" over the axle?
__________________
Old 06-28-2002, 02:14 AM   #4
Zedzag
Hey Talos,I thought you said before that your engine was bored and stroked and it made 381 hp. You even had a dyno graph on your pics page a while back. Now you say it is a stock 350. I'm getting confused. If your engine really has 381 hp then 2.5in pipes are big enough. If you have a stock 350 you don't want to go any bigger than 2.5in or you'll have less power and more fuel consumption. You also said you have dual 3in e-cutouts. How could you have 3in cutouts on 2.5in pipe-did you put a reducer on either side of the cutout? Why didn't you just buy 2.5in cutouts?
__________________
SOLDBlack 95 Z28 M6 Vert.
Daily driver/Auto x-er
Some mods but slow.
Black 1981 Z28 t-tops.
Pro-touring project.
Way more mods and still slow
Zedzag is offline   Reply With Quote
Old 06-28-2002, 02:27 AM   #5
talos
talos's Avatar
wrong car buddy... ya im getting cutouts... i was just wandering cuz i just got some long tubes for the car, then im getting the cutouts... i was wandering if i can run 3" cutouts on the headers cuz they have 3" collectors then i can reduce to a 2.5
__________________
Old 06-28-2002, 02:51 AM   #6
Zedzag
Isn't this your car then buddy?
http://camaroz28.cardomain.com/id/nate400
__________________
Some mods but slow.
Old 06-28-2002, 03:09 AM   #7
81formula'bird
you can just have a muffler shop bend the pipe to fit or you might be able to buy them pre-bent and install them yourself, if your looking for a shop my old neighbour owns an exhaust shop where i used to work and he always cuts people good deals plus he's one of the best i've seen at building dual exhaust setups
Johdy at Quickstops Brake and Muffler
515-4992
__________________
1991 S-10, 4 banger
new project.
Old 06-28-2002, 03:52 AM   #8
talos
talos's Avatar
ya it is... and like i said wrong car... thats not the car im working on.
__________________
Old 06-28-2002, 10:20 AM   #9
Jeff H
Flowmaster sells 2-1/2" over the axle tailpipes so you could put that together from the muffler back pretty easily.
Jeff H - 69 Z28 Hugger Orange, GM crossram, GM fiberglass cowl induction hood, factory TI setup & factory installed JL8 4 wheel disc brakes - original #'s matching and documented, being restored), 87 Toyota 4Runner SR5 Turbo
__________________
69 Z28 Hugger Orange, GM crossram, GM fiberglass crossram cowl induction hood, factory TI setup, heater delete, radio delete & factory installed JL8 4 wheel disc brakes - original #'s matching and documented, being restored
00 SS White/Silver stripes
Jeff H is offline   Reply With Quote
Old 06-28-2002, 01:44 PM   #10
Zedzag
Oh,I thought it was your car.I'd go with 2.5in for tailpipes.I have 3in myself (not mandrel bent)and the clearance is tight.With 2.5in you won't have any problems and it will still support 400+ hp
__________________
Some mods but slow.
Old 06-28-2002, 05:36 PM   #11
jannes
Talking
You cn go with 2.5 inch pipes over the axle and continue with them between the springs and body. It is a tight fit and you have to be careful with the alignment so that they don't vibrate against the body when you drive. That is an annoying sound.
I have my pipes 2.5 just like that and they sometimes hit the body. By having them like this they are sort of hidden from view and just shows up under the rear bumper. Much like the original look.
Remember that the first gen had its muffler in fron of the gastank parallel to the rear axle.
Jan Suhr
Stockholm, Sweden
1969 Camaro Z-28 Cortez Silver with 396 BigBlock
__________________
Jan Suhr
Stockholm, Sweden
1969 Pro Touring Camaro Z-28 Cortez Silver with LS1/T56
www.protouring.se
jannes is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
