1969 leaf springs
Old Jun 24, 2002 | 09:37 AM
fgunnr's Avatar
Post 1969 leaf springs
i have a 1969 6cyl that has been rebuilt as a SS396 M20 4 spd. It still has the mono leaf and 10 bolt rear end. I want to work with the 10 bolt but to use the 5 leaf rear springs. What should I expect with this change and while making this change are there any other changes I should make.
thanks
Old Jun 24, 2002 | 10:48 AM
texlurch's Avatar
The main difference is the spring perches are taller, to make up for the taller spring pack. The u-bolts are also longer. Any set of multi leafs from 68-81 will bolt in. I would also add some polyurethane bushings, especially if you plan on adding slapper bars. The shock p/n is different for multi's also, due to their different spring rate.
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old Jun 24, 2002 | 11:31 AM
Lowend's Avatar
Global West makes a really good conversion kit.
I think the whole kit with springs (really good spings BTW) is $375
1971 Camaro
12" brakes
16x10" wheels
VSE swaybars
350 / M21
Autocross Competitive
'83 FSP GTI (driver)
Administrator; 2nd Generaton Camaro Owners Group (2GCOG)
www.nastyz28.com/2gcog/2gcog.html
Sales / Tech
"The Speed Merchant" - San Jose, CA
http://www.speedmerchant.com/
Collector Car
Dec 17, 2014 01:12 PM
