Old 08-28-2003, 02:21 PM   #1
tbyrne
Weekend Special - Nitrous kit with MSD Window switch combo
We are offering a modified MSD Window switch for $49.99 with the purchase of any regular priced NOS or Nitrous Express system. This will save you $80. off the regular price. This RPM Activated Switch enables you to activate and then deactivate a circuit at adjustable rpm points. This is a great feature for engines using nitrous systems so the nitrous can be turned off just before the high rev limit of the engine. The Switch will provide a ground to activate a circuit and can handle up to 1.5 amps. The rpm levels are easy to adjust with the same plug-in modules used with other MSD rpm controls. It can be used on stock inductive ignitions as well as high performance capacitive discharge controls. You used to have to send the regular switch into MSD to be modified for use with the LS1 motor. We have taken care of this step so the switch will be ready for installation when you receive it.
If you are ordering a system for an LT1 we will included the window switch at no charge (it doesn't have to be modified). Orders can be placed online or by calling 1-877-4-TBYRNE.
Tom
__________________
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR CURRENT SPECIALS and PRICE MATCH PLUS POLICY!
WE HAVE YOUR FORCED INDUCTION NEEDS COVERED WITH ATI, VORTECH AND MAGNUSON SUPERCHARGERS ALONG WITH STS TURBOS!
tbyrne is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
