Stealth Ram install pics
Old Aug 14, 2002 | 11:51 PM
IROCrdracer's Avatar
Thumbs up Stealth Ram install pics
Here are some new pics of the Stealth Ram install-but with some custom additions-
1) Custom three point strut tower brace
2) Custom fuel lines and routing
3) Custom intake welding to accomodate gasket match for FP 1206 intake set
4) Custom plenum porting to accomodate ASM 1300 CFM throttle body
Enjoy!
Stealth Ram
90 IROC,394 ci,vortech YS Trim,Stealth Ram intake, ASM 1300 CFM monoblade TB,Accel DFI, MSD 72lb. injectors,Accel injector cntrl,solid roller-296/306, 658/671 lift
,Tremec TKO, 9" Ford,NX 150 HP shot, Spohn adj ctrl arms-sway bars-race tqe arm-,Ground Control coil overs & camber plates,EDL tower brace, roll bar,Kirkey seat
my pics
[This message has been edited by IROCrdracer (edited August 15, 2002).]
Old Aug 15, 2002 | 12:49 AM
Chuck!'s Avatar
Awesome! The Stealth Ram seems to be getting a little more popular. Plan on taking it to the track or getting dyno #s soon?
Old Aug 15, 2002 | 02:53 AM
RedIrocZ-28's Avatar
You're creating a monster!
Old Aug 15, 2002 | 07:21 AM
Jim85IROC's Avatar
here's a direct link for those that don't want to open a dozen pages to get to the pics:
http://community.webshots.com/album/47046107RtGxwg
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Aug 15, 2002 | 08:30 AM
steve10358's Avatar
3rd Gen Tech Moderator
Jim, that car is BEAUTIFUL.
Wow. That thing should scoot.
Steve
Old Aug 15, 2002 | 08:47 AM
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
Jim-thanks- I fixed the link
my pics
Old Aug 16, 2002 | 10:50 AM
Ucantcme57's Avatar
That's ten times better than the Super Ram, Looks like it has longer runners than the Miniram thou. Where did you get that and where could I get some info on this setup..
Thanks, And great looking car and work!!!
Kevin
Old Aug 16, 2002 | 10:54 AM
http://www.thunderracing.com/index.c...ategoryid=1125
my pics
Old Aug 16, 2002 | 04:14 PM
91RS5speed's Avatar
Well that fit under a stock hood with no stb?
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 17, 2002 | 12:01 PM
91 Formula's Avatar
Did the fuel rails come that way where the custom fuel lines connect in the rear of the fuel rail? Thanks
Looks nice.
Ron
91 Formula WS6
Home Made Ram Air/Cold Air, K&N Air Filter, Air Foil, Holley 19lbs Fuel Injectors, TB Bypass, Underdrive Crank Pulley, Edelbrock High Flow TPI Runners, Ported Plenum, SLP Headers & Complete 3" SLP Exhaust and Muffler, Corvette Servo, Raptor 2800 stall, Richmond 3.73, Spohn Panhard Rod and LCA's, Spohn SFC's and other Poly goodies, Dynoed 254 at crank, 208 rwhp,
91 Formula WS6
14.7 @ 93mph
Old Aug 17, 2002 | 01:58 PM
jayman350's Avatar
wow man that thing looks incredible
what kind of numbers are you estimating for that monster?
Jay
black 85 Z28 - waiting on a new paint job, then she'll be real purty
blue 85 Z28- not running right now, but that should be fixed soon (I hope)
87 Chevy S10 Blazer- 2.8 liters of pure fury
Jay's Website
yahoo im: wildcat856
AIM: Jayman85Z
Homer no function beer well without
check out GMPerformance.org
Old Aug 17, 2002 | 09:48 PM
Cool
<font face="Verdana, Arial" size="2">Originally posted by 91RS5speed:
</font>
Yes, it will fit under the stock hood on a Camaro-barely-will not fit under the strut tower brace.
my pics
Old Aug 17, 2002 | 09:51 PM
<font face="Verdana, Arial" size="2">Originally posted by 91 Formula:
Looks nice.
</font>
Ron- you are correct-the fuel lines are custom from Performance Concepts, and they route away from the rear of the block to avoid heating the fuel.
my pics
Old Aug 17, 2002 | 09:53 PM
Cool
<font face="Verdana, Arial" size="2">Originally posted by jayman350:
</font>
Jayman-thanks for the kudos-we are hoping for 600+ at the wheels.
my pics
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
rjc1629
Jan 27, 2015 10:46 AM
