AFTERMARKET CAMARO COMPUTOR
Old Aug 15, 2002 | 08:12 PM
89 IROC DROP TOP's Avatar
Question AFTERMARKET CAMARO COMPUTOR
DOES ANY COMPANY BUILD A COMPUTOR TO GO WITH THE MODS ON YOUR CAR ???? I CAN'T PASS ILL. EMISSIONS WITH A CAMARO THAT ALWAYS PASSED CALIFORNIA EMISSIONS !!! I REPLACED THE MAF & MAP 'CAUSE THAT'S THE CODES THAT CAME UP, BUT THEY'RE STILL THERE !!!! MEL
Old Aug 17, 2002 | 04:15 PM
formula305tpi's Avatar
Exclamation
Even if you changed the faulty component the trouble code will still be in the computer. To clear it you have to disconnect your negative battery terminal for about a minute. Then the only code you will have are codes that are still in effect or new ones.
'92 Formula, 305 TPI
Old Aug 17, 2002 | 09:18 PM
aklim's Avatar
What have you done to the car?
They have custom ERPOMS that work well. I highly recommend www.fasterproms.com if that is what you want. However, without knowing what you did to the car, who can say what it is doing?
HCz28
Jan 11, 2015 11:21 AM
Collector Car
Jan 5, 2015 10:58 AM
CARiD
Dec 26, 2014 04:20 AM
hotrodyou1
Dec 20, 2014 10:05 PM
