march power and amp pulleys on an 89auto.
Old Aug 17, 2002 | 05:22 PM
pcolaIROC's Avatar
Post march power and amp pulleys on an 89auto.
will they create charging problems, or am i good to go with them?
Old Aug 17, 2002 | 05:37 PM
91RS5speed's Avatar
If everything is in good condition you should be fine. At times in mine the amps get low when im sitting in traffic idleing with the ac on.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
BLK1997Z28
May 7, 2015 03:01 PM
Rde Bandit
Mar 21, 2015 10:17 PM
