Stroke a 350 to 383????
Old Aug 15, 2002 | 06:28 PM
irocdreamer's Avatar
Post Stroke a 350 to 383????
Ok, I read the last thread with the guy that wanted to buy a whole new 383 motor. I am currently looking for a L98 IROC/Z28 OR GTA. If I want to storke it out, what all am i looking at? mI've seen the kits for around $2000. I'm not looking for insane horsepower, the most i'd want is around 400, but 350 is a better number. I know I'd have to beef up the tranny and rear. Fill me in on what i need to do, and how much i'm looking at.
PS: What do you guys think a shop would charge to stroke the 350?
-Brian-
1987 Mercury Cougar
1990 Firebird Trans AM GTA (wrecked 2-5-02 RIP)
Leader of the Nu-Metal Militia!!
Old Aug 15, 2002 | 09:02 PM
RedIrocZ-28's Avatar
You can make 350hp on a stout 350. There is no need to go to a 383 unless #1 You want to have somthing most people don't have. or #2 You want to make 400+. But this is just my opinion. I am planning the next motor buildup... lol I have only 4000miles on this new motor. I would be willing to guarantee 350hp easily with the next combo and still be able to drive it on the street.
I want to put on a set of AFR heads and a Stealth Ram. We'll see. Right now, my best guess is that I am making 290 crank hp or so, according to a 1/4 mile/mph calculation. My combo is in the sig. A set of heads and a high flow intake would for sure get me 50hp.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
Pics of the Iroc
Old Aug 15, 2002 | 11:19 PM
irocbob89's Avatar
Yes, stroking a 350 would be a good idea, however if you want this 383 to make 400hp then your going to have to get some good heads and intake. AFR heads are almost a MUST. The hollie stealth ram, accell super ram, or tpis mini ram will all put up good # on the dyno. You may have a nice engine combo with pore tunning or the engine will run like **** because of something so minor. It took me almost a full year to tune my car right. even after ed wright burned a chip, and after i fryed a set of rings. The engine is torn apart right now so my dad and i can rering it. Once its running (a couple of days) the car should be fast as hell. Now that all the bugs are worked out im happy with the car. Anyways, a 383 stroker (done right) will run you about 5-6k at least, with everything up and running. Good luck and if you have any questions then just post. We will be happy to help you out.
89' red iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89' red Iroc-z
lt-1, 4L60E
free mods, exhaust
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
Rittmeister
Aug 7, 2015 01:13 AM
