lt1/tpi/sbc ?
Old Aug 20, 2003 | 11:02 PM
kacy's Avatar
lt1/tpi/sbc ?
a modified lt1 intake with a set of aftermarket heads work on a standard sbc right?
Old Aug 22, 2003 | 04:04 AM
texlurch's Avatar
I saw something about this on another forum, and it can be made to work, but not easily.
I guess my question is "why bother"?
If you want to go FI on an older SBC, there are plenty of quality stand alone FI kits out there, and will bolt up with NO modifications. You can even use a standard carb type intake to match the flow of your big aftermarket heads.
Old Aug 22, 2003 | 12:21 PM
kacy's Avatar
budget i have looked at all the aftermarket efi @ thier prices of up to 3xxx for the better ones where as a lt1 intake/tpi efi harness & ecu and a sbc would be cheaper and it could be tuned
Old Aug 22, 2003 | 02:28 PM
Piet's Avatar
I got this from another site..
www.lt1intake.com/
LT1 intake conversions for older small blocks... looks nice.
Can't use Vortec heads though....
Old Aug 25, 2003 | 02:55 PM
BluEyes's Avatar
when you say aftermarket, you meak aftermarket SBC heads, ot aftermarket LT1 heads?
Because, the LT1 heads will bolt up to the traditional SBC, but the water jackets are not compatible. You've gotta have traditional SBC heads...
Old Aug 26, 2003 | 11:14 AM
kacy's Avatar
yeah aftermarket sbc heads
Old Aug 26, 2003 | 08:14 PM
willieboy240's Avatar
lt1
they talk about this on the 3rd gen list. its not worth doing. i think the better setup would be tpi with after market heads. the lt1 intake ports and water passages are all different to the older sbc heads.
Old Aug 27, 2003 | 12:04 PM
kacy's Avatar
the reason i selceted that is the tpi stops making power at 4500 cause of the long runners and i would find a set of aftermarket performance tpi heads
