Old 02-21-2002, 01:38 PM   #1
BOZS89IROC
Post Need Help passing Cali emissions
I bought my father-in-laws 84' Camaro H.O.
a couple weeks ago and I am trying to get it to pass emissions the first time. So as to not have to worry about a gross polluter. He messed it up pretty bad. He pulled the catalytic converter and welded in a straight pipe. I have put a cat back in but hye tells me everything on the car is original...everything!!! The O2 sensor needs to be replaced and I'm not sure about the EGR valve but I am going to replace that any way. Do you think I should go ahead and just replace it all or just the major things.
I work at Kragen part time and know there are alot of emmisions parts on this particular car. It has 92k on the O.D. and he has also messed with the carb settings.
Thanx ahead..
Boz
__________________
"No bastard ever won a war dying for his country. You win a war by making the other poor dumb bastard die for his country." -General George Patton
"War is cruelty. There is no use trying to reform it. The crueler it is, the sooner it will be over." -William Tecumseh Sherman
84 Z L69 H.O. Mods? Meet me at the track and find out.
BOZS89IROC is offline   Reply With Quote
Old 02-21-2002, 04:25 PM   #2
CustomX
Get a cat and put it in (hell get a dual cat setup..even better for flow). Replace the egr valve and o2 sensor..make sure that it throws no codes and run the car hot (drive it around town for a little while) then take it to the smog shop..but make sure you dont let that z cool down. Maybe try adding that guaranteed to pass smog crap you can buy. What part of sd are you located in..I happen to know a shop up here in north county that kinda looks the other way when it coems to certain things..if you know what I mean.
Nick Silver @ <A HREF="http://www.iroczone.com" TARGET=_blank>
www.iroczone.com </A>
1990 IrocZ28 B2L
Mods: hmmmm yup I gots parts...
CustomX is offline   Reply With Quote
Old 02-21-2002, 07:19 PM   #3
mod313
Send a message via AIM to mod313
You might want to take it to an emissions cert'd repair shop and have them do a diagnostic run. We have Cal emissions here and our system will allow a diagnostic run through the complete emissions test.I woould suggest doing this before you start swapping parts you may not otherewise need. They should also be able to get your carb adjusted back into spec as well.
mod313 is offline   Reply With Quote
Old 02-21-2002, 07:42 PM   #4
BOZS89IROC
Thanks for your help on the subject. I live in Tierra Santa. Murphy Canyon Naval housing. I'm in the Navy. Going with a dual cat sounds good I was planning on doing that eventually anyway. I think thats what I'll do. I did put a universal cat on there already but it's only bolted on. I figured on the O2 sensor but really didn't know about the EGR Valve. What about the EGR solenoid and TPS. Man this is going to get expensive and take alot of time to bring this car back to life... I love this $h1T.
Thanks again.
Boz
__________________
Old 02-21-2002, 09:45 PM   #5
Kevin91Z
3rd Gen Tech Moderator
Send a message via ICQ to Kevin91Z Send a message via AIM to Kevin91Z
Technically, putting a dual-cat setup on a single-cat car is not smog legal, so be careful you dont get a tech who will hassle you about it.
Check out the local SoCal sites, there are quite a few people who can help you tune the car back up.
1991 Camaro Z28
5.7L T5 TPI (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
__________________
1991 Camaro Z28
364 RWHP, 387 RWTQ (08/09)
12.803 @ 108.50 MPH (04/01)
Member: SoCal Thirdgenners
Work: Manley Performance Products
Kevin91Z is offline   Reply With Quote
Old 02-22-2002, 03:04 AM   #6
CustomX
It mihgt not be smog legal, but it sure wont hurt thats for sure.
1990 IrocZ28 B2L
Old 02-22-2002, 03:27 AM   #7
stanghunter211
Send a message via ICQ to stanghunter211 Send a message via AIM to stanghunter211 Send a message via Yahoo to stanghunter211
Anyone know how much a dual cat setup will run me for my 86 Z ? I have come to the conclusion the with 120K, the cat is pretty well shot. SO rather than dump 400 or so for a new one from GM, I want to know how much I can get the dual setup for. I live In SAn Francisco California, and I would also need to pass emissions. What are the chances of me not passing on the basis of dual cats over the stock single??? I really would like these,but if im not gonna pass, I dunno what to do.! Thanks guys!
Will
'86 Z-28
305 c.i. LG4
Rochester QuadraJet 4bbl
Flowmaster 80 series
Chrome Tips
Dual Snorkel Air Cleaner
K&N Filter
Michellin P215/65/R15 X-Radial Plus
Lots of Mods on the way
Pioneer 4"x6" dash
Pioneer 6"x9" rear
Alpine 8" Type S in bandpass box
Alpine Amp 300x1 bridged
Sony 4000X- x-Plode Deck 50w x4
lots more to come!!!
__________________
89 IROC-Z under construction
*Bone Stock* Dyno 214 rwhp / 312rwtq
14.3@97mph
"in the works... ZZ3/AFR180's/XFI268/LPE Ported TPI"
An old burnout vid
stanghunter211 is offline   Reply With Quote
Old 02-22-2002, 10:17 PM   #8
CustomX
Most techs wont know to look for just a single cat. If they see cats down there...their pretty much satisfied as far as the visual inspection goes.
My dual cat setup just went south on me. Im looking into straight pipe to replace the two until I have to smog it again next year.
1990 IrocZ28 B2L
Old 02-23-2002, 02:23 AM   #9
Kevin91Z
The stock GM dual cat setup probably costs around $1000. If you know a good exhaust specialist, you can have him bend up a 2 1/2" mandrel-bent system like I have. Then get some Car Sound 2 1/2" cats to go with it.
Regarding being smog legal, a local member with an 89 Formula 350 (stock dual cats) was hassled about it. The smog book was wrong, it said dual cats was not an option on 89 cars. He had to take it to another smog station because the first guy would not pass it, even tho it was proved his book was wrong.
__________________
1991 Camaro Z28
Old 08-11-2002, 03:52 PM   #10
Rage
Rage's Avatar
Yeah, hi. Does anyone here know if a smog pump came on the 87 Z28's? I've heard that they did, and then I've heard that they didnt, so I dont know. I live in Harris county and are trying to pass emissions HELP!
__________________
1987 IROC-Z Camaro,305 TPI
LT1/T-56 on the way
http://hometown.aol.com/rage502/myhomepage/profile.html
Rage is offline   Reply With Quote
Old 08-12-2002, 02:49 AM   #11
stanghunter211
I don't see why it wouldn't come with one. If your car was setup to pass emissions, then it has an air/smog pump. Look at your manifolds. That should tell you. My 86Z has one.
Will
'86 Z-28 305 c.i. LG4 165 hp E.T. 16.7 @ 82 mph on radials
Rochester QuadraJet 4bbl,
Flowmaster 80 series, Chrome Tips,
Dual Snorkel Air Cleaner,
K&N Filter,
Michellin P215/65/R15 X-Radial Plus,
Pioneer 4"x6" dash,
Pioneer 6"x9" rear,
Alpine 8" Type S in bandpass box,
MTX Thunder 4202 Amp,
Soon to be sporting a 350 HO somg legal conversion kit. 308 hp Along with Edelbrock Headers, Edelbrock Performer EGR Intake, and 3" Flowmaster Exhaust with DMH Electric Cutout!!!
__________________
14.3@97mph
An old burnout vid
Old 08-12-2002, 12:37 PM   #12
Rage
Rage's Avatar
But will it pass emissions stanghunter? Is anyone else having problems passing emissions? What would you advise me do If It doesnt pass emissions?
Blue 87 IROC-Z Camaro,305 TPI
3" Flowmaster
__________________
LT1/T-56 on the way
Old 08-12-2002, 08:03 PM   #13
stanghunter211
My car is a 4bbl non-serpentine setup. It IS equipped with an air pump. I have never tried passing somg without a pump, but I am pretty sure its necessary, if for nothing more than the visual. But without it "injecting" air into your exhaust gases, you might not pass the sniffer either. My Z passed smog with flying colors. It was actually breathing pretty clean for a 16 year old car. If you don't have a smog pump, you might not pass. But look at your setup carefully. Someone may have modified it at an earlier time because they didn't care to pass emissions. I would put one on anyway.
Just my .02 cents
Will
K&N Filter,
Pioneer 4"x6" dash,
Pioneer 6"x9" rear,
__________________
14.3@97mph
An old burnout vid
Old 08-12-2002, 08:09 PM   #14
stanghunter211
OK, I just realized your in Cali like me. To pass the sniffer you will need the punp. Depending on where you go, some guys don't really care, they just want money. For the right price, they will let you go. But since your HO isn't really a "perfoermer" and doesn't need to do without ait injection, I would say go have it made legal or make sure it will pass. Other things to look out for are EGR, you might also want to change your PCV valve while you're at it, That will proly cost you 5 bucks, but its a good idea. Check for vacuum leaks. Our rides have tons of vac lines. Also, if its an original Cali car, it will have a special emissions package like all ours do. Only Cali got this. And the tech will know by the code under to the hood. Other things they will check to see if are present, catalytic converter, check the carb, check engine light, fuel evap. cansiter, things like that. I got lucky when I bought my Z. It just had an idling problem that was no big deal. I am gonna drop in the 350HO conversion that IS SMOG LEGLA for us since we have 83-86 4bbl cars, VIN G&H I am so psyched. It will sure beat the pants off my 165 hp now. Well, I hope this helps at all. Email me if you have any other questions I might help ya with.
Will
__________________
14.3@97mph
An old burnout vid
Old 08-13-2002, 10:17 PM   #15
carcrazyQT
Junior Member
Send a message via ICQ to carcrazyQT
Red face
Wow! Cali emissions are not what I'd thought. In Ontario, the government runs the emissions testing. Shops can't fake a pass as the actual readings go to the Ministry of Transportation and they regulate what is to be considered acceptable levels. My '84 Zed failed. The testing indicated my factory cat (which has since been replaced by a Dynomax Super Converter) was working at 6%. I was advised by the technicians that a new cat would be all the car needed to pass the next time around.
This emissions crap is a pain in the butt and it's expensive to boot! (Yeah, I know, it's a necessary evil, but anyway...) My car was given a "conditional pass" which means it has 2 years to be brought up to snuff or I won't be able to validate my plates and the car will be yanked off the road. This would suck even more! Gotta love in-yer-face government. Thanks for letting me rant and best of luck.
Tracey
1984 Camaro Z28
305 c.i. LG4
Rochester Quadrajet 4-barrel carb
5 spd trans.
Accel Superstock wires
Accel dist. cap & rotor
Bosch platinum plugs
K&N air filter
Dynomax Super Turbo muffler
chrome tips
Cooper Cobra 235/60R/15 (fronts)
Cooper Cobra 245/60R/15 (rears)
160F thermostat
...and more to come!
http://members.rogers.com/copperchick010
__________________
1984 Camaro Z28
(Lots of new goodies on the way including fresh 350, Flowtech headers, Zexel Torson HD posi, etc.)
carcrazyQT is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
