Do you have details on springs?
Can you provide some more details on the springs (re spring rate Front and Back and amount lower than stock (if any)
Thanks
Kris
__________________
96 WS6 Firebird M6 T's, 52mmTB,TB-Bypass,30#SVO's,ARE Stage 2 Heads & Ported Intake,7/16 studs,Pro Mag 1.6 RR,305 cam,LT4 Ext.Timing set,FLP Headers,DMH Elec.Cutout,160 T-stat,Accel 300+ Ignition,LT4 Knock Module,ODB1 PCM + LT1 Edit,Under Drive Pulley,Prothane:Motor-Tranny&Torque Arm Mounts,BMR:STB-Adj.PHR-Adj.LCA,SLP bolt on SFC's,SLP Billet Flywheel,LT4 Clutch,LS1 Driveshaft, T2R, C5 Front Brakes. Ground Control Coilovers (550/150),Koni SA F Bil R, Strano 35mm bar,Prothane front bushings
