Old 08-15-2003, 01:32 AM   #1
KeVMaN
How much is there to gain by switching to an LS1 driveshaft?
The year one catalog says it increases performance by having less rotating weight and absorbing vibration. Can you guys feel any difference? thanks
__________________
93 Purple Pearl Metallic Z28, Cold air intake, Hooker aero chamber cat back, magnaflow high flow cat, pace setter mids, TB bypass, fan switch, Fully built 91 700R4, 2500 Stall torque converter,TCI Manual valve body, B&M quicksilver ratcheting shifter, BMR SFC's, tubular LCA's and PHR,Lots of Energy Suspension, 3.23 rear end, SS/ZR1 Rims on Kumho rubber, MP3 Player, boston accoustics speakers, lack of finances
project car: 1964 Chevy II Nova
KeVMaN is offline   Reply With Quote
Old 08-15-2003, 05:55 AM   #2
RobK
I switched about a year ago. For me it appeared to make my car bog a little less and have slightly more power down low.
__________________
97 30th Z28 Convertible M6, white/orange stripes (13.8@101, 2.2, 3785lbs)
B&B Triflow, K&N CAI, Airfoil, LS1 Driveshaft, SFC, STB, 32mm solid swaybar, revalved Bilsteins, 1LE LCA's, adj panhard, LS1 front brakes, Pro 5.0, T/A Cover, HPP, !CAGS
RobK is offline   Reply With Quote
Old 08-15-2003, 09:32 AM   #3
rpm4lalo
rpm4lalo's Avatar
Send a message via Yahoo to rpm4lalo
It definately helps to create less vibration.
__________________
LALO aka ZipTie
95 Z28 A4 Daily Driver
95 TA M6 Rarely Driven
06 CBR 1000RR
rpm4lalo is offline   Reply With Quote
Old 08-15-2003, 12:12 PM   #4
coolgenner
That's good news. My 94 car really shakes over 80mph these days. I have the newer driveshaft in my garage, just waiting to do the swap or have it done.
coolgenner is offline   Reply With Quote
Old 08-15-2003, 01:14 PM   #5
KeVMaN
Quote:
my car doesn't really shake at all at top speed tho so i don't know if it would make much difference. if it gives you more power i might put one on tho
__________________
Old 08-16-2003, 01:35 PM   #6
AdioSS
Send a message via AIM to AdioSS
I've been told by some other impala folks that switching from the stock 3" steel driveshaft to a 3" aluminum driveshaft is worth 10rwhp.
__________________
ChestonPhillips@yahoo.com
Quote:
Originally Posted by Bob Cosby View Post
Now we're speculating on the speculation....all the while, throwing more speculation into the mix. Is one speculation (or "most realistic guess") any better than the other speculation?
AdioSS is offline   Reply With Quote
Old 08-16-2003, 06:30 PM   #7
AlexsZ
I know that its almost a requirment when you up to 4.10's...it eliminates the vibration that is caused.
I put one in because I found a sweet deal, couldnt really tell the difference, but, doesnt mean there isnt one.
__________________
2000 SS M6 -- stock, Z06 replica wheels **SOLD**
1996 TA A4: -- stock, daily driver **SOLD**
1994 Z28 A4: -- heads/cam 355, 397rwhp **SOLD**
1974 Plymouth Valiant
1974 Ford Gran Torino
AlexsZ is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
